iNuke 6000 NU4
iNuke 6000 NU4
Getting tired of having to schlep an extra amp rack when I need more than two monitor mixes. My main rack is full and I'm contemplating a 4 channel amp. My rack is full of Crowns and there isn't an option from Crown, so I'm having to look outside to replace the current 2 channel Crown.
First considered the Carvin - a little underpowered and I'll have to reverse the airflow....
Just looked up the Behringer (why is there no emoticon for puking?) iNuke 4 channel amp....more power and $200 cheaper....and I'll have to reverse the airflow on this one too.
I know a bunch of you guys run the Behringer amps......anyone use one of these 4 channel ones? Any comments good or bad?
This is one of those "I don't really need it, but I kinda' want to make things easier" decisions. I can add the two extra inputs and outputs to my current rack panel and save time and effort on every setup.....that extra amp rack with two amps in it is kinda' heavy.....
Re: iNuke 6000 NU4
I have 2 of them and so far they have been great. About 48 volts of output per channel. My only complaint with the inuke's is the iec cable in the back is a loose fit. They are very lightweight but like you mentioned the air flow is back to front.
Re: iNuke 6000 NU4
Since you're looking at the 4 channel inuke I'll assume you don't need dsp.
Personally, knowing the history of Behringer I won't buy them on principle (at least new, and I try to avoid used)
I've had some of their gear, and about half of it hasn't had any issues yet. I've also repaired more gear of that brand for friends than any other (blown caps, etc.)
That being said, they've bought out enough companies that their gear seems to be getting better. I don't have any of their amplifiers, butI don't hear too many horror stories about the inuke series, so it's probably fine.
At 8 Ohms the Carvin here has about the same power as the inuke, (+/- 15W) but is more expensive.
http://carvinaudio.com/collections/dcml ... -power-amp
I'm currently running my mains off a GTD TN-350 given to me. Wouldn't recommend for HT, but for pro sound I haven't had any complaints.
It's not a bad option if you want a bit more modularity. (2 CH, 1 RU, buy 2 -> 4CH / 2 RU)
Here's its little brother: http://www.ebay.com/itm/2-Channel-4500- ... 2c719fdbfc
QSC makes some awesome stuff, but that's in a different price range altogether.
meyers at my job, BFM for my system
2x 24" T48 with 3015lf
2x DR250 with 2510 and melded array
Other hardware comes and goes, but these speakers stay.
Re: iNuke 6000 NU4
I know that the QSC PLD amps are a bit more pricey than you are wanting to spend, but I bought one for running monitors and I abosolutely love it. Plenty of power, and Since most my amps are the Peavey 12m the presets work amazingly. For the 4th of July, I used it to run my FOH. I used yet another preset and it powered my Rig with plenty of volume. (two Peavey TLS 2s for tops and two Titan48's 24 inch wide. Great amp with easy navigation on the front panel/computer!
Re: iNuke 6000 NU4
If I had the money to build a new rig I'd go all the way with the PLD series.
QSC designed custom silicone for them, and the flexibility in configuration options is amazing. I'm just imagining a stack of 4.3's...
Re: iNuke 6000 NU4
I fell into the Behringer Bullshit trap.....their manual says 440 watts at 8 ohms.....I missed the "maximum power" heading.
At 48 volts (as per Corona's post) - that's only 288 watts at 8 ohms.....
That's one reason I hate that company.....they just won't give you straight info.
So, based on that - the Carvin actually has a little more power. Either one would work at those ratings, but I'd really like to have a little more. I guess that ain't happening....so, it boils down to price and reliability.
At a $200 difference - it would be easy to give the Behringer a shot.....(although the gear snob in me really would rather not have that brand in my rack for the world to see).
I'll have to cogitate a little on this.....
Re: iNuke 6000 NU4
yow! 26 pounds for a 1U amp....I'd be looking a over 50 pounds for 4 channels and a lot more expensive.KJ4BXT wrote: I'm currently running my mains off a GTD TN-350 given to me. Wouldn't recommend for HT, but for pro sound I haven't had any complaints.
I like the idea of 1U amps.....but, that is just stupid heavy. My crowns are only 10 pounds.
Re: iNuke 6000 NU4
I'm pretty sure mine's not upwards of 20 lbs. I think that's a typo.
Check the weight on this, it's about right:
https://www.amazon.com/GTD-Audio-Channe ... entries*=0
(Edit)
That's the higher powered model I own, not the one I linked earlier, but should still be similar.
(Edit)
Re: iNuke 6000 NU4
I had a inuke 3k... Sounded loud on mains, but it lost a lot of power on my generator. I was told it was likely due to the inukes not having some power doohickey, so it was looking for 80 amp peaks... On gennie, my Crest LT1000 was noticibly louder @ 280w @ 8ohms... I sent it back and got a used QSC GX7. Inuke1k's work good for W6's though cause the amps aren't getting hammered.
Re: iNuke 6000 NU4
That's a good point NukePooch. You need a solid mains power supply with the inuke's. For generator power look elsewhere. The inuke's don't have any power factor correction so it gulps all its power in short 80 amp bursts rather than a steady 10 amps or whatever the thing draws. I use mine in a perm install with dedicated stage panel so I'm ok there.
Re: iNuke 6000 NU4
Looks more and more like I just need to suck it up and use my crowns.....or build a new main rack where everything will fit. If I took out the Yamaha board I have in the top of the rack, I could mount the driveracks up there and add another amp to the bottom.
Then I'd have to build a little case for the yamaha board......hmmmm.... that almost starts to sound like fun...
Anyway, it would be kinda' silly to buy another amp when I have 3 spare Crowns just hanging around....right?
Maybe there are some winter time projects looming....
- Chris_Allen
Re: iNuke 6000 NU4
I like Behringer, they do what I need them too.
I use the 1000DSP and 2x 3000DSP and they what I need them too but:
A) I don't run them to the limit as I don't need too.
B) If one breaks during a gig, I can work round it.
The Nuke 4 is apparently 2x 3000s stuck together. The iNukes are cheaper and you get what you pay for. I would generally recommend the Behringer as I haven't had a problem but in this case, I would skip it.
The NU4 sounds more like they thought they could get another product out of existing designs which never fills me with confidence.
- BrentEvans
Re: iNuke 6000 NU4
I've used the nu4s in a couple of installs, which gave me a chance to test them nicely. I find them adequate for situations that aren't very demanding. They make good monitors amps. They do fine for mains when you're not pushing them to the limits (8 ohm loads, reasonable volume levels). They are weak for subs unless bridged, which negates the effectiveness of the four channels unless you're running two tops and one sub. In this case, bridging is to bond the power supplies for more capacity rather than solely for voltage increase.
Peavey IPR2 amps (and crest prolite if you prefer) are far superior for not much more money.
Re: iNuke 6000 NU4
Best I can tell though, is that they don't have a 4 channel option....BrentEvans wrote:
- BrentEvans
Re: iNuke 6000 NU4
The don't, but I don't buy or recommend amps based on that.Bruce Weldy wrote:Best I can tell though, is that they don't have a 4 channel option....BrentEvans wrote:
If the desire is four amp channels in two rack spaces, Qsc pld is the way to go, but they have limitations too. Power soft has some too I think...
Might be less expensive to just get another rack....
