It's +6dB for every doubling of cab count (assuming they are properly powered like the first). 1 cab=as chart, 2=+6dB, 4=+12dB, 8=+18dB, 16=24dB (etc)chrisj360 wrote:If I was to try to approximate the output of multiple T30's (I have the Lab12 loaded and I think the 3012LF is the closest match), I would just add +3 for each cab added like so?
Is this correct or did I miss something?
Introducing SPL Chart
Re: Introducing SPL Chart
Could we get the T-45 with 3012l, in 15 and 24" versions, please? (Plus 18 or 20 would be a pleasant bonus, too
CoronaOperator
[spl width =650&height=450&fmin=20&fmax=120&dbmin=85&dbmax=125]T60W15DLab12+12,T45W24DLab12+12,T60W30DLab12X2+6,JBLSRX728+8.1[/spl]
Last edited by CoronaOperator on Mon Mar 16, 2015 10:24 pm, edited 1 time in total.
- Drey Chennells
nice chart thank you
InfraCoustik
Consulting/Design/Fabrication
Authorized BF Builder
http://www.infracoustik.com/
info@infracoustik.com
InfraCoustik
CoronaOperator
I'm trying to see if 4 Tubas @ 50 volts are a suitable replacement/improvement over 2 SRX728's @ ~70-80 volts hence the +12 dB's and +8 dB's added to the charts. Looks like a build thread coming soon.Drey Chennells wrote:nice chart thank you
- Drey Chennells
hell yea good choice
InfraCoustik
InfraCoustik
No, I thought you had modelling software that eliminated the need to build every idea that comes out of your drafting table.Bill Fitzmaurice wrote:Do you propose that I build and measure a cab in every conceivable size loaded with every conceivable driver? That most assuredly is not going to happen.
Where's the fun in that?!Rich4349 wrote:No, I thought you had modelling software that eliminated the need to build every idea that comes out of your drafting table.
Luke the Fluke
sorry justl ooking at something
Chris_Allen, will the Simplexx line-up be added anytime soon?
- Chris_Allen
I lost the up to date source code for the application I wrote to do the sampling. So I'm trying to find the time to update an old copy.
DJPhatman wrote:Chris_Allen, will the Simplexx line-up be added anytime soon?
Still waiting....Chris_Allen wrote:I lost the up to date source code for the application I wrote to do the sampling. So I'm trying to find the time to update an old copy.
1 1/2 years later, and still waiting...DJPhatman wrote:Chris_Allen, will the Simplexx line-up be added anytime soon?
- Chris_Allen
Point taken.DJPhatman wrote:1 1/2 years later, and still waiting...DJPhatman wrote:Chris_Allen, will the Simplexx line-up be added anytime soon?![]()
Sorry, mate! But, sometimes the stick just makes you.Chris_Allen wrote:Point taken.DJPhatman wrote:1 1/2 years later, and still waiting...DJPhatman wrote:Chris_Allen, will the Simplexx line-up be added anytime soon?![]()
CHECK, PLEASE!!!! An ode to someone elses "Get my coat!"
