Driverack PA 110 to 240V Conversion
SimonD
#1 Post by SimonD »
Hi Folks
I did the 240V conversion to the Driverack on the weekend. Pretty simple process once you have the transformers. I couldn't get a direct replacement so I had to get two separate transformers. One is a 10V secondary and the other a dual 17V secondary.
I started by removing the screws on the side.
Then the centre top allen screw only
Remove the top cover to expose the torodial transformer on the right
Unplug the connector, remove the transformer and cut the connector off it (point of no return :-))
Wire the two new transformers primary windings together and fit spade connectors
Solder the secondary windings to the connector
Put a few strips of double sided tape on the underside of the transformers
Mount the transformers and plug the connector back in. A few strips of double sided tape with the one side covering strips still on secures them further.
Power back up (with the cover back on) and its good to go :-)
Hope this is of some use as the Driverack only cost US$148.00 and about $120 for transformers and freight etc. as opposed to $550 in Australia.
2 x DR250 (Kappalite 3010MB, ASD1001S)
2 X T39 24" (Kappalite 3012LF)
Re: Driverack PA 110 to 240V Conversion
#2 Post by Grant Bunter »
I applaud your efforts S.
Well done.
Wouldn't it have cost less still to order in a 240V version???
SimonD
#3 Post by SimonD »
Grant Bunter wrote: Wouldn't it have cost less still to order in a 240V version???
I couldn't find anywhere to get a 240V version from, at least not for anything close to that cost :-)
My system is just getting better by the day, our drummer just purchased a new Berringer X32 producer desk and dropped it off to me to setup for the band :-)
Cheers S
#4 Post by Grant Bunter »
SimonD wrote: My system is just getting better by the day, our drummer just purchased a new Berringer X32 producer desk and dropped it off to me to setup for the band :-)
Cheers S
Oh how cool is that!
Us drummers, much maligned, really we're just misunderstood hehehehehe
Have fun learning a new toy...
Rune Bivrin
#5 Post by Rune Bivrin »
Looks cool. But I can't help thinking you've gone overboard on the VA rating on those trannies. The dual 17V probably powers the audio circuits, and I'm guessing a 15VA tranny would have sufficed. The 10V winding is probably for the 5V supply to the digital circuits, and most likely that would require something in the same realm.
Not that it matters, but I'd be a bit wary of the transformers coming loose in a mobile scenario.
In build order:
O12 with no tweeter.
3 x WedgeHorns.
2 x Jack 10 without tweeters.
2 x DR250.
2 x 16" T39
1 x Tuba 24
2 x SLA Pro (sort of...)
SimonD
#6 Post by SimonD »
You are 100% correct Rune :-), it is WAAAAAAY overrated, but they were all I could find in stock, in Australia, on that day :-)
Don't worry the transformers are nice and snug in there, they wont go anywhere.
