AntonZ wrote:kekani wrote:Honestly, each time I see someone starting an OT12 build I always thought to myself "Why not just do a pair of DR's and be done with it?"
Consider me humbled.
You make me laugh more than once on this build thread. Thanks for sharing Kekani, and extra kudos for spicing it up with humor
Then you and I must have a similar sense of humor. Glad for that.
Seriously, when I did my first build(s) and shared the thread, I did so with the intent of paying it forward for the other threads that have helped me so much. I think therein lies the value of this forum. However, I think most of us may be a little hesitant to show the faults; there are brave exceptions of course.
I guess I'm at the point that I didn't give a rip, because if I'm struggling, someone else out there is as well, just may not be saying it. And that's okay.
I struggled on this one, mostly because of increasing the difficulty on my own accord, so its my fault, really. I don't know if its a good or bad thing that I waited to do these.
Good in that I knew what to expect in the plans.
Bad in that I thought I knew what to expect in the plans.
Either way, yes Grant, resistance was futile. . .
Chris_Allen wrote:It does look noticeably skinnier with the 3/8".
I think the title is misleading! Doesn't look much wrong for a first DR200 build. My first pair were quite bad in comparison with the 2nd and 3rd pair!
With the thinner ply, I would consider some small blocks in the upper corners of the horn to add a little strength.
I titled it this because I didn't want to mislead anyone into thinking this is the way a DR was designed to be done by the plans. You have no idea how many times I was thinking, "If this were 1/2", I'd be done." Especially when it came to using pocket holes, or not using them because I didn't use 1/2".
I was just a little overconfident in thinking I could make 3/8" work, especially with a statement that I've read, "I'd feel confident building the cabs out of 3/8" ply, but it would take too much conversion on the dimensions."
I'm pretty good at math. But not that good. Damn all those angles
I've built lites out of 1/4" (with serious bracing of course), and the 3/8" that looks noticeably skinnier to 1/2" is very solid. Especially when the CD module is in place. Confidence in tight PL butt joints, with a solid baffle and proper bracing pulls it all together.
SimonD wrote:I have to agree with Chris, it looks like a damn fine build to me
Look who's talking about a damn fine build. Your fix on the CD module? Like a boss!
I just realized, it must be something different that makes you guys down south build some nice stuff. Maybe its the toilet draining in the wrong direction
You know, at this point, it seems almost done, and then I go and pull out the filter parts. Even though I've done them a few times now, my brain still feels like
Anyone ever seen a filter done on a "U" shaped board just so it fits? Coming up soon.
