Life has been extremely busy here with family, work and an upcoming career change with me going back to school part time. Lots of homework for the next 4 years, work and family life don't stop so build time will remain scarce for a while. I have just finished my first series of 4 exams so a tiny little bit of spare time before lessons kick in again next week. So trying to get moving again on my pair of SLA pro when I am not at work.
My apologies to Grant for not anwering a good suggestion, thanks Grant. For the grills I found an affordable sheet of extruded aluminium, already sprayed black. Very light, I am not sure though if it is strong enough. There are indeed similar websites over here so if it does not work, I will keep my eyes out for some used cabs on the local used market.
For now, I need to add damping to the cabs. The plans call for 1/2" felt carpet padding. Not sure if I can source that locally. However I may have just enough egg crate foam in stock for the pair. Now I don't want to damp too much and create dull/deadened sounding cabs. Will I be overdamping if I use egg crate foam instead of 1/2" felt padding on all internal surfaces?
After damping it is the home stretch with just mounting of hardware, drivers and grill remaining
