Microphone Stand Vacuum Holder
Most of us folks on the forum not only have woodworking shops of whatever size but also a lot of sound equipment that we usually don't use while we are in the workshop. I was working recently on a non audio project, mortising in some hinge cups for kitchen cabinets when I needed to set up my shop vac to collect the mountains of chips that the mortising bit threw off. I grabbed a boom stand, affixed a mic clip from my Sennheiser wireless microphones and was able to get the end of the hose in exactly the right position to collect most of the chips. What you can't see in the picture is the speaker stand holding the clip light over the work but I have ben using speakers stands for years for everything from holding lights to holding lasers. What's next, Black and Decker microphhone stands?
Re: Microphone Stand Vacuum Holder
Genius. Absolutely. I am using this TODAY>
I like it! So simple.
Frédéric Gélinas, HF Audio
Authorized Builder
HFAudio.ca
Free tone Generator
Authorized Builder
HFAudio.ca
Free tone Generator
This is what makes this forum so great! Improvise, keep it simple and carry on. Good call my friend.
- Harley
Nifty idea!
I can cover the mike stand, now for a shop vac.
It's a great idea!
I'm still using the "get covered in sawdust/sweep sawdust up with a broom" build area management method...
It's a great idea!
Not good, Grant. You are breathing in all that crap every time you make with any sawdust... sanding, cutting, any thing. Here's to you getting a vacuum or other dust collection system in place.Grant Bunter wrote:I'm still using the "get covered in sawdust/sweep sawdust up with a broom" build area management method...
You forgot the 'get phonecall, step outside and jump around beating your clothing to remove as much sawdust as possible' step. I think most snacks and drinks I've had since I started making things have been at least minorly contaminated with sawdust.Grant Bunter wrote:I can cover the mike stand, now for a shop vac.
It's a great idea!
My compressor has been turned on non-stop for 27 years.....and the air hose is always laying on my work table. Nothing quicker for cleaning yourself up.88h88 wrote: You forgot the 'get phonecall, step outside and jump around beating your clothing to remove as much sawdust as possible' step.
Ah so that's what those are for!
Truly the most used power tool in my shop.88h88 wrote:Ah so that's what those are for!
It's a documented fact that most people don't get enough fiber in their diet.88h88 wrote: I think most snacks and drinks I've had since I started making things have been at least minorly contaminated with sawdust.
T48s
WH8s
SX212
T48s
WH8s
SX212
