Good idea on printing the Sketchup. It appears you are using the older style plans with the access in the top rather than the front.miked wrote:Nice job, Bill! Isn't it amazing how long it takes to lay out your cuts, cut all the panels and braces, etc?
One piece of advice. The baffle (panel 2, I believe) has different angles on the top and bottom edges. Make sure you have the panel sitting proper-side-up on the saw before cutting the angles. Printing out a side view of the cab in Sketchup was invaluable for me. That way, I had a visual reference of how the panel would be oriented in the cab, and knew what side of the panel to cut which angle on. Hope that makes sense. Also, I actually labled my baffles with an arrow pointing up towards the top of the cab and wrote "Top of cab" next to the arrow on all the baffles.
I already have the instructions 3-hole punched and in a binder by the table saw. And have my cut list printed out.
Having the fence calibrated and the moving table square has really helped - once a sheet was up on the saw I could make the 4 cuts pretty quickly, and then had pieces that were much easier to handle. I've just got a few more braces to cut from my 4th sheet of BB.
