(My) First TRT
(My) First TRT
Long time no post...
It will go in the back of a Citroen Berlingo, flat on the floor with the driver facing down (on spacers)
Just starting out...
Authorized Builder
- 6 DR290
- Omni10.5
- AT, TAT
- Tuba 48
- 2 WH10
- Truck Tuba
http://www.boniton.co.il
- 6 DR290
- Omni10.5
- AT, TAT
- Tuba 48
- 2 WH10
- Truck Tuba
Re: (My) First TRT
Looking good so far. Be sure to use PL or other polyurethane adhesive to assemble it.
Re: (My) First TRT
err...you're preaching to the choirmiked wrote:Looking good so far. Be sure to use PL or other polyurethane adhesive to assemble it.
Mark Coward
Re: (My) First TRT
Mark Coward wrote:err...you're preaching to the choirmiked wrote:Looking good so far. Be sure to use PL or other polyurethane adhesive to assemble it.
Mike hasn't been around long enough to have seen Mr. Webber's builds.....maybe we need some pics to update the newer members of his prowess?
Re: (My) First TRT
Whoops. Er, my apologies. I see the DR-something in his profile pic...that shoud've tipped me off. To make full resolution for my mistake, I shall apply a 4-inch long bead of PL to one of my hairy forearms and let it dry. Over the next 3 months as it slowly chips away, I will be reminded of my folly.
Re: (My) First TRT
Hey mike, please don't do that. This would be a total waste of good PL.miked wrote:Whoops. Er, my apologies. I see the DR-something in his profile pic...that shoud've tipped me off. To make full resolution for my mistake, I shall apply a 4-inch long bead of PL to one of my hairy forearms and let it dry. Over the next 3 months as it slowly chips away, I will be reminded of my folly.
Simple Superglue will be fine...
Authorized Builder
- 6 DR290
- Omni10.5
- AT, TAT
- Tuba 48
- 2 WH10
- Truck Tuba
- 6 DR290
- Omni10.5
- AT, TAT
- Tuba 48
- 2 WH10
- Truck Tuba
Re: (My) First TRT
See if you can find mr Webber's WH10 build thread, Mike
Looking forward to see what you come up with on this one, Nimrod. Your work is always a source of inspiration (and a bit of frustration as well: my work looks like in comparison ).
Re: (My) First TRT
NOW I remember. He routed his initials in his WH10's or something like that, right? I think I posted in that thread too.AntonZ wrote:See if you can find mr Webber's WH10 build thread, Mike
- Bas Gooiker
Re: (My) First TRT
I dont have the plans to the truck tuba so this is the first time i see this thing. Looks good Nimrod!
But i wonder, Bill has been critisising the "scoop" / rearloaded horn in another thread lately. Calling it a flawed design because of the phase difference between the direct radiating driver and the horn.
I am no expert but this looks like a rearloaded horn to me though. I hope Bill could chime in on this.
Re: (My) First TRT
Maybe, Nim's is the shot for the TAT on the sales page with NiM routed on it.miked wrote:NOW I remember. He routed his initials in his WH10's or something like that, right? I think I posted in that thread too.AntonZ wrote:See if you can find mr Webber's WH10 build thread, Mike
Just in case:
http://billfitzmaurice.info/forum/viewtopic.php?t=14761
Looking forward to seeing this build as well...
- Scott Brochu
Re: (My) First TRT
Shit I hate that, when it happens. You put the tube down and no matter what...I always get some on my arms, pants, shirt and even my pencil. And I wear gloves.miked wrote:Whoops. Er, my apologies. I see the DR-something in his profile pic...that shoud've tipped me off. To make full resolution for my mistake, I shall apply a 4-inch long bead of PL to one of my hairy forearms and let it dry. Over the next 3 months as it slowly chips away, I will be reminded of my folly.
Drumming is a way of life.
ME LIKE TO HIT THINGS!
Re: (My) First TRT
It is. The cancellation notch is moot, because it occurs well above the subwoofer pass band. The same is true of tapped horns, which also are rear loaders.Bas Gooiker wrote:I am no expert but this looks like a rearloaded horn to me though. I hope Bill could chime in on this.
Re: (My) First TRT
Excellent work as usual, looks like a pretty straight forward build too. I think I'll have to make one of these.
Re: (My) First TRT
Similar idea to the TT, then?Bill Fitzmaurice wrote:It is. The cancellation notch is moot, because it occurs well above the subwoofer pass band. The same is true of tapped horns, which also are rear loaders.Bas Gooiker wrote:I am no expert but this looks like a rearloaded horn to me though. I hope Bill could chime in on this.
Re: (My) First TRT
EPIC THREAD IN PROGRESS!!
Tickets..get 'yer tickets, right here! ...TICKETS!!
