2x 19" T30's
Charles Jenkinson
Re: 2x 19" T30's
#46 Post by Charles Jenkinson »
No words tonight from me. Its half 3 in the morning, and Noah has his 1st drums lesson at 9am.
2xT30
Charles Jenkinson
Re: 2x 19" T30's
#47 Post by Charles Jenkinson »
Not sure the effort of the holes is worth it in 6mm ply braces, but theyre in there now.
2xT30
Re: 2x 19" T30's
#48 Post by Tom Smit »
Charles Jenkinson wrote: Its half 3 in the morning, and .......
From what I've learned in Dutch, that's the same as .....hal-ef dree (phonetic spelling by me). 8)
Bas Gooiker
Re: 2x 19" T30's
#49 Post by Bas Gooiker »
But if i remember correctly half 3 in the UK means 3:30, hal-ef dree in Dutch is 2:30.
Re: 2x 19" T30's
#50 Post by Tom Smit »
Ok, I'll wait for the definition from Charles. :)
Charles Jenkinson
Re: 2x 19" T30's
#51 Post by Charles Jenkinson »
Half 3 is indeed three thirty (3:30). It's a colloquial shortening of half past three.
2xT30
Re: 2x 19" T30's
#52 Post by Tom Smit »
Weird.
Bas Gooiker
Re: 2x 19" T30's
#53 Post by Bas Gooiker »
Tom Smit wrote:Weird.
You should see the side of the road they drive on, thats weird! :lol:
EDIT: Sorry Charles for the thread de-rail. Build is looking good, carry on.
Re: 2x 19" T30's
#54 Post by AntonZ »
Bas Gooiker wrote:You should see the side of the road they drive on, thats weird! :lol:
Don't get me started on the beers they drink :owned:
Re: 2x 19" T30's
#55 Post by Tom Smit »
:D
miked
Re: 2x 19" T30's
#56 Post by miked »
Cabs are looking great and the braces look real solid. Next time I build subs, I will only cut the windows out of the large braces. Of course I'll cut holes in any braces that the plans say NEED holes, but other than that, it's not worth the trouble IMO. In my T48 build thread I weighed the braces before and after cutting. IIRC I saved about 3 pounds. Totally not worth the half a day it took to hollow them all out, not to mention all the sawdust I had to clean up.
Charles Jenkinson
Re: 2x 19" T30's
#57 Post by Charles Jenkinson »
A bloke in my first job used to tell me regularly why we drive on the left; because swords are drawn from and therefore worn on the opposite side to the persons dominant hand, and most are right handed, so when getting on a horse one has to mount from the left (kerb) side.
I'm fine with a bit of side tracking. Thank you gents. :-)
2xT30
Charles Jenkinson
Re: 2x 19" T30's
#58 Post by Charles Jenkinson »
Panel 7 installed last night: Cut mitre on bottom edge; routed handle using an oversize jig template (made using holesaw again) - Sheesh, how many router set-ups are required! 14 handle pockets to route and roundover in total, for 2 cabs. Gonna try and do as many panel handle pockets as possible next time, to reduce total set-up times.
Panel 7 braces to do.
The glue has been scraped off in the photos shown, to ease clean up, but there was squeeze out.
Also, just wanted to show BF name plate I made and glued on back of the J12L's - i agonized over where it could be stuck on the front but figured it wouldnt work for my finishing detail/style. I made 4 of these half size laminated tags, before I'd committed to building the subs, which is nice. Am gonna stick the tag above the jack sockets again on the subs.
Last edited by Charles Jenkinson on Tue Sep 24, 2013 6:47 am, edited 1 time in total.
2xT30
Charles Jenkinson
Re: 2x 19" T30's
#59 Post by Charles Jenkinson »
Laminated name plates - somewhat smaller than the ones available in aluminium.
2xT30
Re: 2x 19" T30's
#60 Post by Chris_Allen »
Charles Jenkinson wrote:A bloke in my first job used to tell me regularly why we drive on the left; because swords are drawn from and therefore worn on the opposite side to the persons dominant hand, and most are right handed, so when getting on a horse one has to mount from the left (kerb) side
It was also the polite and non confrontational way of riding as the person passing on their horse could see your weapon hand. (Apparently!) How much of this is actually true, I've no idea......
