Elder Audio Beta3 Amps
Is this amp OK?
Re: Elder Audio Beta3 Amps
#16 Post by Grant Bunter »
Caveat:
Cross your subs higher than 100Hz if the rest of the system doesn't keep up.
One of the main advantages of crossing 100Hz and below is that the sub cabs become omnidirectional. So you can run a stack of subs in the corner and it doesn't appear that's where your LF is coming from...
Bas Gooiker
#17 Post by Bas Gooiker »
Armchair Pirate wrote:Really? Duel 12" T60 cabs no higher then 100hz? there is so much life between 100-160 hz though....* I do mostly EDM music.
You can run BR boxes way over 100 to cover low mid, but folded horns tend to sound "honky" when played higher. A good bandpass horn design with a single fold like the http://hornplans.free.fr/turbo_bph238.html will kick like a mule and cover 70-180 nicely.
sine143
#18 Post by sine143 »
there may be a lot of life above 100, but your tops should still be capable of covering it, not your subs. 24 db slope at 27 to 30 hipass, or 48 at 25. no higher than 24 db slope on the lopass imo.
just because there is output up above 100 hz doesnt mean its a good idea to use it. since it IS a range that tops can cover, its best to dedicate your massive sub boxes to.... well, sub bass. asking them to produce 4 full octaves is pushing it imo.
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
Armchair Pirate
#19 Post by Armchair Pirate »
Thank you everyone, this has all been great information and I will be doing some more testing and experimenting once my boxes are working again.
Built so far
4x Duel Lab 12 T60 30"
Next
2x DR280
2x D12 T60
