2 x Jack 112 Lite
Charles Jenkinson
Re: 2 x Jack 112 Lite
#61 Post by Charles Jenkinson »
I like your style Grant, and you may have a point. Without analyzing this to death (one wouldn't want anyone losing sleep (...aghem!) over the heinous pillow prices here in the UK) I'll send my Mum down to world famous Bury market and see what she can turn up.
As for therapy, it is pretty cheap. I am still however holding off telling my wife the sum total of the numbers till we get nearer the end. Fortunately, she has a good appreciation of my therapy requirements.
2xT30
DAVID_L_PERRY
#62 Post by DAVID_L_PERRY »
Looking good Charles !
Look forward to seeing them and hearing them at some point, will have to organise a trip over as we are pretty close.
Dave
Previous obsessive speaker building disorder.....(now all gone to new homes)
2DR290s, 4 DR280's, 2 Titan 48's, 1 Omni 10, 1 Wedghorn and last but certainly not least:- The Omni 15....super sweet basstwangtastic....
#63 Post by Tom Smit »
DAVID_L_PERRY wrote:Looking good Charles !
Dave
Hey! Where did you come from? Good to see you back!
Sorry, Charles.
Charles Jenkinson
#64 Post by Charles Jenkinson »
No need to apologize. :-) If a thread facilitates people doing the stuff, I'm happy.
2xT30
Rick Lee
#65 Post by Rick Lee »
Tom Smit wrote:Hey! Where did you come from? Good to see you back!
+1
Authorized Builder
Nashville/Middle Tennessee
bwtaudio@gmail.com
DAVID_L_PERRY
#66 Post by DAVID_L_PERRY »
Yep, not posted on here for a long time....Stopped making cabs for a while, and then got back into producing small runs of pretty traditional (ie baffle loaded) bass cabs - Yes I know...I was drawn back to the dark side :D
Tend to pop in and have a gander at the build threads once in a while as I like to see bits of wood forming into cabs
I am always bobbing around on http://www.finnbass.com/ and that has a good BFM section as well
Dave
Charles Jenkinson
#67 Post by Charles Jenkinson »
It's been very hard moving forward through these minor sheaths install phase, fiddly detail and numerous parts, but now there is progress to report.
Here's a picture of the top hat trial fitted, with a spacer the same shape as the top flange, for the screws to bite into. The upstand braces are not in the final position - this is dry run.
Last edited by Charles Jenkinson on Sat Mar 30, 2013 5:08 pm, edited 1 time in total.
2xT30
Charles Jenkinson
#68 Post by Charles Jenkinson »
Rollered blackness, a combination of brush application and rollering with a custom roller I made.
2xT30
Charles Jenkinson
#69 Post by Charles Jenkinson »
Here is the custom roller. 20mm wide standard (non textured) foam roller, cut down from a standard 4" roller element. Fitted into a plastic handle on something i was throwing away.
2xT30
Charles Jenkinson
#70 Post by Charles Jenkinson »
In use. Though not necessary on the external surface shown here.
2xT30
Charles Jenkinson
#71 Post by Charles Jenkinson »
The first minor sheath, stapled, glued and afterwards, trimmed back on the overhanging edge.
2xT30
Charles Jenkinson
#72 Post by Charles Jenkinson »
On the second one fitted via the use of staples, the staples punched through the 3mm ply at one side causing it to delaminate and not join properly, hence the clamp and batten to try and glue it back into place and line accordingly. I decided at this point that stapling these minor sheaths was a bit of a pigs ear job and not easy to do neatly.
2xT30
Charles Jenkinson
#73 Post by Charles Jenkinson »
I proceeded in the clamping manner with the last 2 sheaths, by feeding the clamps through the bass ports.
2xT30
Charles Jenkinson
#74 Post by Charles Jenkinson »
The other end of the clamps sat nicely on the end of the braces that support the whole bass port structure.
Hopefully things will move better from here on.
2xT30
Charles Jenkinson
#75 Post by Charles Jenkinson »
Except that this one didn't work. The force conponent from the clamp is not onto the curved brace pieces. It's a stroke of luck if the clamps curve the wood and it curves in the profile shape of where It needs to be. May need a combo method or staples and clamps.
EDIT: On closer inspection, the sheath was too wide in the lower regions and being trapped between the side sheaths wouldnt fit down onto the profiles where it needed to be. Need to trim some width off.
2xT30
