what clamps and how many to build a thtlp and where to buy
Hello. I plan on building a tht lp and some sla's to start with. Can someone recommend what clamps, what size and how many I need and where to buy them?
thanks
thanks
- SoundInMotionDJ
Re: what clamps and how many to build a thtlp and where to b
Clamps....you need more. When you think you have enough....get more. Every trip to the home improvement megamart...toss a couple more clamps into the cart.
Pipe clamps...two or four long enough to cover the largest dimension of the sub.
Quick release clamps....four small, four medium, four large.
C-clamps....half a dozen to start...then start getting more.
He who dies with the most clamps wins!!!!
10 T39S + 10 DR200 + 1 T48
+ 1
2 x Jack 112
2512, one with melded array
To do list:
XF 212
2 x Jack 112
To do list:
XF 212
I use washer-head pocket hole screws to build my cabs, and remove them once the PL cures.
The only part that has required clamps on those builds is when I attach the flange for the access panels. In that case, no more than 6 steel bar clamps. On the last THT build, I ended up using only two pipe clamps.
If you do buy, I recommend sticking with either Adjustable Clamp Company, Bessey, or Quick-Grip.
But if you'd like to save some money on clamps, use screws. IMHO, it's easier.
+1 on that.Radian wrote: ...
- SoundInMotionDJ
Clamps & a brad gun is both faster & easier than screws....but to each their own.Radian wrote:But if you'd like to save some money on clamps, use screws. IMHO, it's easier.
--Stan Graves
What can I win? Yet more clamps?SoundInMotionDJ wrote:He who dies with the most clamps wins!!!!
There really is no such thing as having enough clamps in the shop.
I think this is still running. I know I jumped on it.
http://www.ptreeusa.com/edirect_012213.htm
- Jon Barnhardt
discount doesn't seem to be working anymore
+1Jon Barnhardt wrote:discount doesn't seem to be working anymore
