need help find rabbet bit
I am building a t18, and i am going to do an inlaid access cover. The plans say to rout a 9/16 channel around the cover, but i can't find a rabbet bit that big. Any suggestions. Thanks.
2xTHT
AutoTuba
T18
Table Tuba
AutoTuba
T18
Table Tuba
Re: need help find rabbet bit
i just used a pattern bit with my plunger router. basically was able to freehand it and just stay in the lines.
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
1x bastard XF208
Use a 3/8" or 1/2" mortise bit, use two passes, limit the router cut width with a guideboard or one of these, set to stop the router base:Billy Joe wrote:I am building a t18, and i am going to do an inlaid access cover. The plans say to rout a 9/16 channel around the cover, but i can't find a rabbet bit that big. Any suggestions. Thanks.
http://www.amazon.com/E-Emerson-Tool-C5 ... pd_cp_hi_0
The mortise bit was my first choice. I just thought maybe there was rabbet bit big enough to do it. I hope i don't screw this up to bad
Thanks for the help.
2xTHT
AutoTuba
T18
Table Tuba
AutoTuba
T18
Table Tuba
