It wouldn't look out of place in a finnish saunaCharles Jenkinson wrote:All stapled up. My wife thinks it would make a nice lamp shade.
Seriously, looking very good. And great to have a helper like that.
It works just fine, in appropriate quantity.Charles Jenkinson wrote:Here's how not to do it. My fillet faux pas. Bad idea to use expanding adhesive to make a fillet. Need to use a different substance. not sure what yet.
The trick is not to try and smooth it down with fingers AT ALL! Wait 12 hrs, then trim with a box cutter and/or sharp chisel. You can also prepare the curved syrface by applying maksing tape, but I found this wasn't really worth the effort.Charles Jenkinson wrote:Bad idea to use expanding adhesive to make a fillet. Need to use a different substance. not sure what yet.
Why do you think you need to make a fillet? Is it purely out of cosmetic reasons you want it?Charles Jenkinson wrote:Ok. I'll cut off the mess I have made, and put one healthy bead down as a 'fillet', and then leave it till tomorrow. This feels counter intuitive in terms of it doesnt feel like its going to give a neat radiused fillet.
Charles Jenkinson wrote: The other point is I could be getting anal, and duratex sorts all this out....
Yes, I have done just that - radiused fillets on my latest J112 Lites. I cut the PL out as I described above ( after 12 hrs ) and used MSS ( modified silicone sealant ) for the fillet. This was AFTER I sanded the curve and the flat surfaces.Charles Jenkinson wrote:Yes, I think the fillets would be for cosmetic reasons.
As for the radiused fillet, do people not bother doing them, or find that they can achieve them with PL? ..
$NZ 1,710.00 WOW!Charles Jenkinson wrote:
Total: £877 for a pair.
Therapy is quite cheap then, isn't it? Sometimes that's not factored in.Charles Jenkinson wrote:An update.
So, here’s the list of my UK costs for building a pair of Jack 12 lites:
<big list>
This has been spread over 18 months. ... I do wonder what the UK retail cost would be, but it’s slightly irrelevant – I think of it more as cost-effective therapy.
