I made some sawdust today. I rough cut all the panels, numbered them, and started the first few steps. I'm heading to the hardware store for some allen bolts for the driver and epoxy for the T-nuts. Then I will glue down the first two inner panels to cure. I have learned from the previous builds to move slowly and let the first couple of steps be absolutely perfect, then it's easy sailing the rest of the way through.
The lines are down with some pin-holes ready for fasteners on the last panel. I forgot to do this on one of the T48s, and won't do that again.
Hole for the driver and pilot holes for the 10-24 T-nuts.
I used a 1/2" routed edge so that I could get the hole for the driver as small as possible without the surround contacting it on excursion. A Jasper jig is on my Christmas list.
Manual range of the excursion shows that the surround is clear of the baffle, so now I'll run a test tone through just to be safe.
