2 x DR250 (melded) + 2 x DR250 (CD horn) March 2012 plans. Completed
Re: 2 x DR250 build, mostly based on March 2012 plans
Hey Grant, nice work once again mate! Great build thread.
Built: 2x Jack 112.
Bass: Cort Action A.
Amp: GenzBenz Streamliner 600.
Thanks Jono
They won't be too bright if you have adequate EQ. They can be if you don't. Switching the resistor position should only be used if your EQ isn't up to the job.Grant Bunter wrote: I need to mull over how to make the piezo filters fit on a small piece of 1/4" ply and leave enough tails on the 4 ohm resistor in case I find the piezos too bright.
Thanks Bill!Bill Fitzmaurice wrote:They won't be too bright if you have adequate EQ. They can be if you don't. Switching the resistor position should only be used if your EQ isn't up to the job.Grant Bunter wrote: I need to mull over how to make the piezo filters fit on a small piece of 1/4" ply and leave enough tails on the 4 ohm resistor in case I find the piezos too bright.
I won't need to worry about that then, I have ample EQ...
The DEQ2496 I bought a while ago will be reserved for FOH
Just spent a couple of hours on filters and wiring melded array...
It's to cold for yesterdays paint to be dry yet.
It's snowing.
Here's the filters and the wired up array:
I have the lever action strippers and the artery clip in the pic for good reason.
I use the artery clip as a heatsink for all electronic work I ever do. It does a good job of protecting components and is also handy to hold things together. Heatsinking the components lets me stay a little longer with the soldering iron which helps prevent bad solder joints.
If you can find a medical supply store nearby think about getting one!
The lever action wire strippers:
The thought of cutting 40 odd bits of wire and soldering them all was unappealing and fidgety.
It occurred to me if I cut a longer than required piece of light wire, then used the lever action strippers to strip back, starting from the middle of the wire (and the middle of array), loop that over the lug then solder, same for the next lug, working all one way then back the other, I would only need to cut and strip each end.
I ended up pulling the lever action 2 to 3 times in each spot to expose enough wire.
It worked a charm, about 20 minutes to do the whole array...
edit: re (just) above regarding stripping wire. Seems it's not new at all. Tom has described this in another thread. Maybe I'm taking in stuff from this forum subliminally now lmao
Enough for today, got cattle to feed
It's snowing.
I think that I would always want to use the 4 ohm resistor....just in case. You know...for all that it costs, why not.
Nice build so far.
Nice build so far.
Thanks Tom on the build comment.Tom Smit wrote:I think that I would always want to use the 4 ohm resistor....just in case. You know...for all that it costs, why not.
Nice build so far.
I agree regarding the 4 ohm resistor and it is there.
I'm not the world's best photographer so the pic is a little blurry.
It's in line (almost) with the cap on the filter board on the right hand side of the pic.
The 4 ohm is on the left side of the board and the 30 ohm is on the right...
edit: Just to clarify to all, that pic is 1 x LF LP and 1 x HF filter, built separately for 1 cab, as per plans
My opinion?
You should move to QLD. Had a lovely 27 degree day yesterday, paint would have dried quick then
BassMe wrote:My opinion?
Good on ya Bassme, we left Longreach on Monday just past and it was warm and sunny the whole time we were there (though cool at night).
I'm becoming more patient... and it's not like there isn't more to do!
Don't you people know that its summer time? It's like you are on the other side of the world.....sheesh.....
Is it?Bruce Weldy wrote:Don't you people know that its summer time? It's like you are on the other side of the world.....sheesh.....
Who woulda known!
Titanium Hand
Snow! Wow thats why the apples taste sooo good
We've had a few cold days in Sydney too... 12 degrees maybe he he he
- Harley
It's because they are now imported from NZTitanium Hand wrote: the apples taste sooo good
Being in an apple growing region, I refrain from saying anything...Harley wrote:It's because they are now imported from NZTitanium Hand wrote: the apples taste sooo good
Otherwise it would be multiple 4 letter expletives starting with f and c etc.
Does fire blight ring a bell?
Not only is your weather screwed up - you guys can't even seem to run a proper spelling bee.....Grant Bunter wrote: The f one would be fire and c is after b. It's not 4 letters but does blight ring a bell?
