Bill Fitzmaurice wrote:What matters most is that the back braces, and then the horn braces attached to them, are offset from the cab center. I wouldn't try to move the throat divider.
Sorry Bill, I missed your post before I gave it a go....
In order to fix up my... errr... mistake
I cut out the horn throat divider, and lined it up with the middle back braces, which come towards the bottom of the cab, with their top edge on midline, meaning they are offset.
After the repair the horn throat divider also remains offset as it is now on the opposite side of midline.
If being one side of midline is required for better mid range response, it is still that, and now it is also lined up with the braces...
I hope this is clear.
Cutting out the throat horn...
PL'ed back in place inline with the middle braces and now offset below the midline rather than above it as it was before (you can see where it was) :
I will need to reapply hot melt glue to the reflectors in a few spots when the PL has set...
That handy little hacksaw blade holder has been in my toolbox for 20 years.
Just as I was nearly done cutting it broke. Plastic, therefore not repairable, well not where it broke anyway.
I wonder if I can find a new one...
