Hi all,
I need a decent suplier for the 1mH inductor and the 10uF capaciors for the low pass filter in my omnitop 12s.
Does any one know of anywhere decent (*cough* cheep)?
Just as a side note, Im a little confused how adding a low-pass filter to the woofer can improve the high frequency responce??? Can anyone explain this to me?
all the best,
Doug
						UK suplier for crossover componants
"The impedance of the woofer naturally increases with frequency. Above 500 Hz it increases enough to reduce current flow, causing loss of response. To counteract this a low pass filter is inserted in the driver circuit. This filter reduces impedance in the midrange to allow higher current flow, and therefore increased sensitivity from 500 to 3.5 kHz. "
OmniTop 12 plans, page 22.
- DAVID_L_PERRY
Cheers Dave,
I cant seem to find an apropriate inductor at CPC... here is the search
http://cpc.farnell.com/jsp/search/brows ... tid=419491
the only one that seems correct has a DC resistance of .46 ohms
do you know anywhere else?
Re: UK suplier for crossover componants
http://jantzen-audio.com/html/dealers.htmlDoug86i wrote:Hi all,
