digi mixers question
greetings.
time to buy a digi mixer so i can preset the mix configuration. Presonus STUDIOLIVE-16.0.2 Digital Mixer, vs the digi pre set yamaha entry level mixer or anything else rather small sized and similar. i only use 8 channels. which one, why or why not? price is not important. i wont buy behringer.
the presonus DOES NOT have FX on / off ability via 1/4 jack going to a simple foot switch, which i find disgusting. . . they reccomend a $129 tech 21 midi mouse and you change midi #'s or channels for FX on to FX off. midi mouse has 3 switches on it and you have to look down to see which one to hit, which two not to hit. i care too much about my performning and am too busy to be looking down at the ground at 3 switches. smart design morons. . .
entertainers who leave FX on while talking must have never experienced a professional concert. if i have to, i'll use my yamaha outboard FX WITH A FOOT SWITCH thank you.
i work dueling pianos and do corporate shows and i'd rather not have to walk the room 3 or 4 times to check the mix while my partner performs the first 2 songs without me and there's a room full of people. also, because he likes his monitor mix individually specific and loud, i hear the bleed of his voice and have his vocals a tad low in the F.O.H. mix. i can perform fine like this but i do not get a true read on the room mix. sometimes in corporate world there isnt opportunity for a sound check, you just make it work. preset mix is the goal. system EQ is easy as i seldom have to adjust the EQ.
i run Left out for F.O.H., Right out to me for my monitor. i hear the exact mix the room does and yes i know my read - the sound - of my tiny monitor is different than the F.O.H. system but i'm looking at the mix here.
also important, do i need to go to college to figure out how to work these things and / or how is tech support on the phone? i want to invest the scrilla in a couple days. appreciate any input
Re: digi mixers question
I agree with your gripe about the FX on/off footswitch - but, other than that - the Presonus board is amazing. Every time I think of something I can't do, I figure out a way to do it. And it doesn't take digging into menus to pull it off, it all on the board. The only thing I have to go to a menu for is the graphic EQs on the mains and aux outs. Everything else is on the board. And on the 24.4.2, I think the graphics are via a button too.
thanks, i appreciate your input. it's only $ and 1 can always get more $. i'll wait a day or so and see if anyone else has any thoughts. any thoughts? - i'm opening up a can of "awe-what-da-hell".
Personally, I can't justify the cost, or size of most digital mixers. Of course, my friend goes to NAMM and comes back to tell me check out Line 6. Huh?
Still can't find a reason to justify this, but I'd like to play around with it to see if I even need a reason to.
http://line6.com/stagescape-m20d/overview
Of course, if it were just for fun, this would be more along the lines for me.
http://www.mackie.com/products/dl1608/about-the-dl1608/
Funny, I just got my iPad last year and was thinking about sound processing apps (especially after handing around here), and then the dl1608 shows up.
Aaron
Aaron
Wedgehorn 6 (x2)
Jack 110 Lites (x2)
XF212 (Egnater style)
DR200 ASD (Yes! Finally!)
Jack 110 Lites (x2)
- jswingchun
That thing is so cool. Seems really well designed and thought out.kekani wrote:Still can't find a reason to justify this, but I'd like to play around with it to see if I even need a reason to.
Omni 10
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
the line 6 item looks great. cost more than double the entry level presonus. my biggest concern is the same for ALL new on market digi stuff, i wait a year or so as there usually are problems. these companys put this stuff out a.s.a.p. because if they wait 6 months for field testing, they'll lose thousands of dollars in sales. line 6 is great stuff, so i'd NEVER put a noisy crappy heavy beavis & butthead amp on stage with products like the line 6 amp modelers and such out there but then i'm too reasonable, besides, bar cords trigger the mindless no matter what they are processed through.
the line 6 will be a big seller.
Have you looked at a used Yamaha 01V ? It is proven, inexpensive and reliable, although you would have to use midi for control.
Builds:
T-39
DR 280
Wedgehorn 8
Omni 12
SLA
TAT
TLAH experimental
T-39
DR 280
Wedgehorn 8
Omni 12
SLA
TAT
TLAH experimental
+1biodad wrote:the line 6 item looks great. cost more than double the entry level presonus. .
For $500 less you can get a Presonus 16.4.2 that has 16 mic inputs vs. 12 and 6 aux sends vs. 4.
Not to mention, it's been out on the market for a few years now and is proven. Don't get me wrong, I like Line 6 (still have my POD) - like biodad said....give 'em some time in the market.
biodad, if you ever want to try out a Presonus 1642 at one of your gigs, let me know. I'm in Mpls. Also I have two of your old Jacks!
very kind of you sir. thanks. i ordered the presonus 16.0.2 or whatever the smaller one is. easier to get more $ than it is to live with a cheapskate within . . .
You'll like it.biodad wrote:very kind of you sir. thanks. i ordered the presonus 16.0.2 or whatever the smaller one is. easier to get more $ than it is to live with a cheapskate within . . .
Have a sound gig this weekend doing a Pink Floyd tribute band. The promoter had told me what was going on and it looked like I had everything covered, but I called the band leader anyway......uh oh....seems as though there was going to be an extra singer, a sax player, an extra guitar amp, and prerecorded music.....
Through the use of the aux inputs I'll be able to get 19 channels out of my 16 channel board. I know you can do that on other boards, but I'm able to route the aux ins to sub-faders for control and I can eq the aux ins and send 'em to any monitor mix just like a regular channel. These board are really versatile. I would have been in real trouble without it.
The subgroups are so flexible I wish there were 8 instead of 4. You can set up the routing so they control FX levels, "bonus channels" such as the aux ins, or I've used them for front fills, delay fills/sound fx, or i'll assign bass/kick/keys to Main AND a sub and use it for "sub-fed" subs
Yep, I have my Reverb and Delay routed to Sub 3 and 4. And it's all in a rack-mountable format.mattaudio wrote:The subgroups are so flexible I wish there were 8 instead of 4. You can set up the routing so they control FX levels, "bonus channels" such as the aux ins, or I've used them for front fills, delay fills/sound fx, or i'll assign bass/kick/keys to Main AND a sub and use it for "sub-fed" subs
And the best part is the firmware upgrades at no charge. You don't have to worry about it being obsolete two months after you buy it.
Yep, when bought my StudioLive the iPad didn't even exist yet. And now I can mix wirelessly with it.
Good choice on the Presonus, I mix for a band who have there own PA. They have the 1604 only took me
a little while to get used to it. Plus there are quite a few videos from there live webinars they hold these every so often.
I was used to the outboard f/x but I get what I need from the onboard f/x just fine, also they got the Ipad interfaced also.
It's great to walk the room and mix and go up and ring out monitors. If anything check these out http://presonus.com/community/presonuslive/
" Everyone Has a Photographic Memory, Just Not Everyone Has Film In The Camera"
4 x T48 24.5" 3015LF
8 x 112 Otops
NEXT 2 x DR280's
8 x 112 Otops
NEXT 2 x DR280's
