Obviously this thread is based on the easier of the two to builds, the titan 48. Dust should begin flying within the next week or so, until then I need help figuring out what drivers to buy. Now, I know the Lab 15 is the primary suspect here, and Im cool with that. However, Im really needing to run 4 ohms if I can. Ill be pushing these with a Crown xls 602's (http://www.crownaudio.com/amp_htm/xls.htm#specs). Considering this, I wont have a lot of watts spare in my opinion; thus in importance of running at 4ohm. Now, the Lab 15 runs at 6 ohm and at a vd of 968 (http://www.parts-express.com/pdf/290-575s.pdf) vs. the Dayton titanic at over 1500 (http://www.parts-express.com/pdf/295-420s.pdf).
Now, the plans specifically state that Vd is king here. I know, I know; the Lab 15 is pro level and what not. But what if your not running these everyday? What if your running your subs say 10 times a year, and at 200 watts below the rms value of the subs (I say this considering the titanics rms at 800 and the 602 xls pushes at 600 watts rms at 4 ohm). Considering this Im thinking the titanic might be worth considering..or for that matter the Peavy low rider 15 (http://www.peavey.com/assets/literature ... _13679.pdf).
I dont know, I want the ohms offered by the titanic, the stated performance offered by the low rider and the dependability of the lab 15..please help!!!
