LP recomendation for non BFM folded horn
Charles Warwick
#1 Post by Charles Warwick »
Hey guys so I've got a not quite tuba question but you're the guys I go to for this stuff
I built a Selenium Pro audio folded horn about 3 years ago using these plans
I built it (before I found you guys of course :lol:) and made it half the width (20'') of the plan for easier transport using this15'' woofer
Specs:
300 watts RMS
Fs: 33 Hz
Vas: 11.1 cu. ft.
Qms: 5.13
Qes: 0.32
Qts: 0.30
Xmax: 3.0 mm
This thing has been sitting in my garage for a while now acting as a table and garage sub so I decided to sell it on Craigslist to fund my T39 build :hyper:
Now here's my question the guy I had come over listen to it wanted to put some more power into it as I was only using an old 100w peavey, but I don't want it to blow during the demo. I agreed to meet him again tomorrow, take the sub outside so he can hear outside without a room since he'd like to be able to do outdoor shows with it, and put some more power into it.
What frequency should I low pass it at, and what recommendations for my xti 2000 do you suggest? -6 or -12 db limiting? The horn is probably a 10 ohm load, so the xti would give about 69 volts, so a -6db is about 34V (115 watts) and -12db is 17V.
I'm awful at measuring path length since I'm never sure where to place my line, but if I place the tape measure along the path it's about 4-5-ish feet, which tells me this thing is like a 60hz horn. :conf:
Does it really mean that, that huge heavy thing that is bigger than my TT only goes to 60hz?? :noob:
I guess I'm just spoiled, but that just seems awful... :fruit:
The plans for the sub says it "can be used from 40 to 200 Hz with maximum efficiency" but I'm not sure I believe that after looking at the numbers...
What do you guys think, cross at 50hz and call it a compromise? :roll:
Re: LP recomendation for non BFM folded horn
#2 Post by Bill Fitzmaurice »
As far as the horn loading goes yes, that's it. Below that it works as a direct radiator, with direct radiator sensitivity. With only 3mm xmax I wouldn't put more than 100 watts per driver into it, high-passed at 40Hz.
SeisTres
#3 Post by SeisTres »
:shock: This thing looks ALOT like the design I've been playing with. I think this is going to help me, thanks man. :D And yeah, as Bill said, with that xmax, I'd high pass at 50hz and no more than those watts.
Dave Non-Zero
#4 Post by Dave Non-Zero »
Plans say on page 2 that the medium length of the horn is 147.2cm.
Saves any tape measures. ;)
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
Charles Warwick
#5 Post by Charles Warwick »
Dave Non-Zero wrote:Plans say on page 2 that the medium length of the horn is 147.2cm.Saves any tape measures. ;)
:slap: Hahaha, nice, I'm so unobservant. :lol:
Here's a picture of it in case anyone is curious: http://i10.photobucket.com/albums/a104/ ... SC2308.jpg It effectively looks like a T30 without the extension. :roll:
So, the guy came over today and I hooked up my xti 2000, -6db limiting 48dB HP at 45 hz and 110hz LP, on one channel and the two OT12's on the other.
Sounded quite loud wedged in a corner of the garage, not so much when the guy pulled it out of the corner to see what it sounded like 5-6 feet out (well duh), and pretty decent when we moved it outside. A good bit weaker outside especially when he choose some dubstep as a sample material so it wasn't especially loud since part of the bassline seemed to be below 50hz. :?
But regardless, he seemed satisfied and hauled the monstrosity away and left me with 200 bucks! :hyper: The damn thing was made of 3/4 MDF and weighed far too much.
Now I get to go to Lowes tomorrow to buy some plywood for 2 t39s. Excellent. :ugeek:
Thanks for the advice guys! :mrgreen:
Dave Non-Zero
#6 Post by Dave Non-Zero »
result! :loler:
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
Mikey
#7 Post by Mikey »
Glad to hear that you're "on the road to recovery"!
:clap: :hyper: :clap:
Albert Einstein
#8 Post by DJPhatman »
Charles Warwick wrote:Now I get to go to Lowes tomorrow to buy some plywood for 2 t39s.
Unless your Lowes carries 1/2" 5-ply Arauco, don't bother. If there is a Menard's close by, phone them and ask for "Baltic Birch" or 5-ply fir or pine. Tell them you are building cabinets, but you don't want any thin veneers.
SeisTres
#9 Post by SeisTres »
+1, call around first since (in my area) only a few lowes carry it, not all of them.
Charles Warwick
#10 Post by Charles Warwick »
DJPhatman wrote:Unless your Lowes carries 1/2" 5-ply Arauco, don't bother. If there is a Menard's close by, phone them and ask for "Baltic Birch" or 5-ply fir or pine. Tell them you are building cabinets, but you don't want any thin veneers.
I have checked around various places and still have yet to find BB in the central iowa area for a reasonable price. Our local lumber yard used to carry it but went out of business a few years back :cry:
I can get BB in Des Moines (about 45 minutes away) for about 70 bucks a sheet, but I can get the 1/2 Arauco from our Lowes here in town for 20 bucks a sheet, so the Arauco wins for me.
On a side note, has anyone been noticing a good amount of voids in the Arauco they've been buying? These are the mouth panels for 4 J110:
It might have just been that sheet, I don't know, but I feel like there are more than there used to be...
Voids are a problem with cabinet designs that use large unbraced panels. We don't.
SeisTres
#12 Post by SeisTres »
Wow, that sucks. My three arauco that I got about three weeks ago are almost flawless, even better than the ones I used first and those were better than what you posted.
subharmonic
#13 Post by subharmonic »
Looks about like most of the acuaro I get.
I need more bass
CW Mcall
