As noted on another thread, I am now building a pair of WH10s that will be fitted with a curved grill.
This is the modified Sketchup model:
Here are some pictures of the build:
Cutting the baffles and spacer rings:
Cutting out the throat opening:
Gluing spacers and baffles:
Baffles ready with t-nuts:
Routed edge of side panel (mod from original plan)
Routed recess for Speakon dish:
Shell panels Ready with braces:
First shell panel attached to side panel:
Second Panel:
Second side panel:
Horn jig in place:
Front edge of horn side panels are aligned for additional thickening strip
(This is another mod/addition to the plan needed because of the curved front - will be clear later...)
Routing the front edge/curve of the side panels:
Thickening of the dish opening edges:
The outer shell in 'work' position:
Managed so far...:
