digital_chris wrote:Second, I don't have the room for 2 of these or even a dual loaded cab. I think I might try the wider version (17") though to squeeze out more low end, possibly even the 19" with a ten inch driver. Would I get even MORE low end with a ten?
A dual loaded TangBand W8-720 AT can be 18" internal, 19" external. You will gain +6dB over the single driver AT of the same width. (+3dB for halving the impedance, and +3dB for doubling the Vd).
You gain nothing from a 10" driver. When the HL10C, which was the king of 10" pro subwoofers, was around, Bill wrote in the plans that it works no better than the cheaper 8" MCM!
