otop 15
Is this amp OK?
billgwaltney
otop 15
#1 Post by billgwaltney »
I am finished with the two otop 15s with the flat arrays. I am looking at purchacing a new amp today and am wondering what the right power rating would be. I put the neo kappite 15s with the piezo that were called for in the plan. Eminence rates the 15s at 450 watts and music at 900 watts. I was unalbe to find if the 450 is RMS or what. 70.7 percent of peak is RMS in the electronics world so I dont know where to music 900 rating comes from.
Tom O'Shea
Re: otop 15
#2 Post by Tom O'Shea »
The 450 should be RMS. 2xRMS seems like industry standard for "program" or "music" power ratings.
Tom O'Shea
Authorized Builder
Auburn, AL USA
billgwaltney
Re: otop 15
#3 Post by billgwaltney »
So a 1000 watt bridge amp should be fine with these ran in parallel
Re: otop 15
#4 Post by Bill Fitzmaurice »
billgwaltney wrote:So a 1000 watt bridge amp should be fine with these ran in parallel
No. Never bridge. Bridging is properly used to deliver higher voltage output into a high impedance load. If you aren't pushing a 16 ohm load you don't want to bridge.
IMO anything rated for 300w/8ohms per channel or more is plenty enough to drive OTop 15s, and four of them at that.
billgwaltney
Re: otop 15
#5 Post by billgwaltney »
Thanks for the information. So much to learn and so little time hehe
