Where did you end up repositioning the crossover?Chris_Allen wrote:I repositioned the crossover so I could have one pair of DR200's with hats in both sides - this was so I could stack them using a short piece of 35mm connecting pole.
DR200 (x4) Build Thread
- Scott Brochu
Re: DR200 (x4) Build Thread
Drumming is a way of life.
ME LIKE TO HIT THINGS!
- Chris_Allen
Good question! I'm not sure where I put it. I'll have to take a cover off and take some pictures.Scott Brochu wrote:Where did you end up repositioning the crossover?
WOW!! What a GREAT thread! It was crazy informative and answered a questioned I had. I was going to build 2 DR-250's, but I believe I like the idea of the four 200's instead.
Man, I really enjoyed this. Well done and thank you so much.
Patrick
Patrick
"If it's too loud, your too old! What's that? I didn't hear you"
Friends don't let friends use crappy speakers!
- David Carter
Glad it was helpful, and good luck with the build. Make sure you share your journey also.NCcrashman wrote:WOW!! What a GREAT thread! It was crazy informative and answered a questioned I had. I was going to build 2 DR-250's, but I believe I like the idea of the four 200's instead.
Dave
- 2 x Titan 39 (BP102 - 14"W)
I really like the idea of the tin/metal back halves. Does it affect sound in any way?
- David Carter
I don't believe it has a significant impact. Of course, I've never built DR200's without the metal in order to compare. But regardless of whether they're the same or not, they sound great!
Dave
soundinmotiondj was actually the one that started doing the metal thing. I'm pretty sure he hasn't had any problems with them. Might want to PM him just to verify.BoostFab wrote:I really like the idea of the tin/metal back halves. Does it affect sound in any way?
Nah, Harley was.
- David Carter
@BoostFav, regardless of the origins, Stan (SoundInMotionDJ) does indeed have a herd of DR200's with the metal butt cheeks, and he uses his a lot more than I use mine, so he will definitely be able to offer an opinion on how they sound.
Dave
well, I guess that does give itself away being tin halves are non-issue, since you both have deployed the herd.
I'm very tempted on switching from ot12 and build the dr200, after digesting the plans like 10x it doesn't look too hard IMO
great build and log
Just a short question, it's ok to add poly-fil inside this area, good to go?
LC
LC
Currently Built:
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
Yes, just don't pack it tight.Lastcat wrote:Just a short question, it's ok to add poly-fil inside this area, good to go?
LC
- SoundInMotionDJ
I have 10 metal butt'd DR200's. They sound fine to me. No vibration. No buzzing. Clear. Articulate. Stupid loud.BoostFab wrote:I really like the idea of the tin/metal back halves. Does it affect sound in any way?
But, I have not heard a wooden butt'd DR200 to compare against.
10 T39S + 10 DR200 + 1 T48
Ok, thanks Bill.Bill Fitzmaurice wrote:Yes, just don't pack it tight.Lastcat wrote:Just a short question, it's ok to add poly-fil inside this area, good to go?
LC
Currently Built:
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
