Corners for OT12's
djtecthreat
Corners for OT12's
#1 Post by djtecthreat »
I ordered corners from Leland for my OT12's and all along I figured I wouldn't care much if they overhang where the access cover and grille are but now that I get down to it- I don't like it.
I was looking at these- http://www.speakerhardware.com/penn_elc ... wc1567.php
Would these NOT hang over the access cover/grille area? I'm using 1/2" ply w/ a 3/8" round.
DJ TecThreat
-Building-
8 More T48's
-Built-
4 SLA Pro's
SeisTres
Re: Corners for OT12's
#2 Post by SeisTres »
djtecthreat wrote:I ordered corners from Leland for my OT12's and all along I figured I wouldn't care much if they overhang where the access cover and grille are but now that I get down to it- I don't like it.
That's what I'm using on all of my four jacks now. I actually tried one of the bigger ones and it was HORRIBLE. But with the little ones, I can open the back(although I do have to wiggle it some), and they look very cool since the front edges stop basically where the 1/2" stops. I too used 3/8" roundover. Now my cabs actually look like cabs and not some black wooden boxes :slap:
#3 Post by LelandCrooks »
That corner is now the default corner for all tops. It fits well and is proportionate to the cab size. The bigger 1405 is what's in all the subs.
I personally prefer the metal corners, but if you're stacking cabs the 1567 is what you want.
djtecthreat
#4 Post by djtecthreat »
I prefer the look without corners, but I used arauco on the OTs and I'm concerned about the corners.
I'm also not stacking corner to corner, I put feet on them. Any pics of a cab with metal corners? How do they fit on the 1/2"?
DJ TecThreat
-Building-
8 More T48's
-Built-
4 SLA Pro's
David Carter
#5 Post by David Carter »
djtecthreat wrote:Any pics of a cab with metal corners? How do they fit on the 1/2"?
I don't have my DR250's anymore, so I can't take additional pics, but here's a leftover pic of a DR250 with metal corners and rubber feet. Sorry it's not that clear. This cab had a 1/2" roundover, and the corner fit just fine.
Dave
- 2 x Titan 39 (BP102 - 14"W)
djtecthreat
#6 Post by djtecthreat »
David, What are you using for screws? Button head wood screws?
DJ TecThreat
-Building-
8 More T48's
-Built-
4 SLA Pro's
DaveK
#7 Post by DaveK »
He's probably using black 1/2" truss-head screws. PE sells them and Leland may also.
I didn't like the way screw heads scratched things around them so I've switched to pop pivets for metal corners. It's a cleaner look, at least to my eyes. Unfortunately, the local big box store does not carry them in black so I have to use aluminum.
bzb
#8 Post by bzb »
I just threw the corners on after mounting the back. I've opened my Fender 15" cabinets once in 8 years.
Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
David Carter
#9 Post by David Carter »
djtecthreat wrote:David, What are you using for screws? Button head wood screws?
I've already replied in a private email, but for the benefit of others, I'm pretty sure I used #6 x 1/2" pan head screws and painted the heads black. If I had to do it over again, I'd get black screws from Leland. I also like the pop rivets idea. You could paint those black also.
Dave
djtecthreat
#10 Post by djtecthreat »
bzb wrote:I just threw the corners on after mounting the back. I've opened my Fender 15" cabinets once in 8 years.
It's not so much about functionality as it is about looks. I like things looking symmetrical, maybe i'm crazy.
DJ TecThreat
-Building-
8 More T48's
-Built-
4 SLA Pro's
