Is it kosher to discuss the crossovers?
DrDoug018
Re: Is it kosher to discuss the crossovers?
#31 Post by DrDoug018 »
mpm32 wrote:Is Doug's drawing correct?
The pics are nice, and I like Harley's but it's hard to see the connections in the pics.
Thanks
I'd like to know that too :-)
FWIW, the cabs sound great and the EQ curves I got from the RTA seemed to be reasonable (I need to post those).
I also edited my earlier post with the diagram to include a photo of the actual crossover. I probably should have used something more secure than hot melt to attach the components to the board. I'll go back in this summer and add some straps or something.
Doug
2 DR250
2 T39 (20" 3012LF)
2 Jack 10
1 Omni 10
mpm32
#32 Post by mpm32 »
Well, if they work and everything sounds good, I'm going to use your diagram.
Thanks.
https://www.facebook.com/CharlieDontSurfCT/
2-DR250
2-Wedgehorn 8
2-16" T39
bzb
#33 Post by bzb »
I think Doug's tweeters are reversed. But in the plans (and in this thread) it says to check polarity afterward, so I'm not sure.
Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
gnemonic
Jack 10 crossover problems. Please help
#34 Post by gnemonic »
Hi. I made a crossover using the compression driver for the hights and low pass for 1-10. 2Kh 8omh. Place everything in the same board. It sounds great but when I turn the volume up the, sound compresses and a weird noise comes out. Could the coils be talking to each other? I forgot to place the big low pass one at 90 deg. I followed the intructions but I could be missing something.
This is my first crossover project so I'm a little lost.
Thanks in advance for any help. :noob:
#35 Post by LelandCrooks »
Pic please.
I had my first bad one a while back. Squealed like a stuck hog when the customer cranked the cab. Never made a peep when I tested it before shipping the cab.
Kirk Baptista
#36 Post by Kirk Baptista »
Just finished my first one, thought it came out OK.
Have no idea how it sounds yet, but soon!
Custom Fender 5 string PBass
Ibanez SD 530 4 string
Gallien Krueger MB Fusion
2 Jack Stack, Kappalite 3012HO
yeahforbes
#37 Post by yeahforbes »
What's an easy way to mount a crossover into a Wedgehorn? Putting it on the access panel would be simple, but I'd prefer not to have wires connecting it to the rest of the cab. The side panel with the jackplate would be ideal, but the proximity of the horn side makes driving screws just about impossible. I'm a bit scared to PL it there, in the interest of repair access.
N.Webber
#38 Post by N.Webber »
yeahforbes wrote:What's an easy way to mount a crossover into a Wedgehorn?
Authorized Builder
- 6 DR290
- Omni10.5
- AT, TAT
- Tuba 48
- 2 WH10
- Truck Tuba
http://www.boniton.co.il
yeahforbes
#39 Post by yeahforbes »
Nice! If only I hadn't already strapped down my parts in a layout an inch wider than the plate... haha. I managed to get it on the side where I wanted it... couple screws on the close side, right by the large coil, and it's way more sturdy than I thought it would be.
#40 Post by Bruce Weldy »
I just drilled a hole in 'em and put 'em on top of the mattress topper using a wood screw (not drywall) in two places. Screw 'em in by hand slowly. You can get plenty of grip in 1/2in. ply without going through.
#41 Post by LelandCrooks »
Pull the mattress topper out from under it. Use spacers of some kind. I have some 3/8 nylon ones I supply with prebuilt xovers. If there was ever a problem, the resistors can get hot. Mattress topper burns very nicely.
#42 Post by Bruce Weldy »
LelandCrooks wrote:Pull the mattress topper out from under it. Use spacers of some kind. I have some 3/8 nylon ones I supply with prebuilt xovers. If there was ever a problem, the resistors can get hot. Mattress topper burns very nicely.
Can it get hot enough to burn through the 1/4" plywood it's glued to?
#43 Post by LelandCrooks »
No, but the ply will transfer the heat.
#44 Post by DJPhatman »
Bruce Weldy wrote:Can it get hot enough to burn through the 1/4" plywood it's glued to?
It can also get hot enough to cause the glue to soften and release its' bond. Run some zip strips over the resisters and through the 1/4" ply.
