Beta 8a damage
High output and wide dispersion without feedback.
Windmill
Beta 8a damage
#1 Post by Windmill » Tue Nov 13, 2018 8:56 pm
Just today I scored a couple of beta 8a’s for about half price in brand new condition. They arrived in the mail but one was damaged. The speakers were placed face-to-face but they were not zip tied together. The frame of one speaker damaged the cone of the other speaker. There are some dent marks and a partial flattening of the spider. There does not appear to be any coil rubbing. Will this affect the X max of the speaker? Should I recone it? I have been offered a refund so this speaker is essentially free to me. Any advice would be greatly appreciated thanks.
2 Jack 10's Beta 10A's, piezo array
2 Jack 10’s, Beta 10A’s, NSD2005
2 WH 6 panel mount
2 WH 8 panel mount
Crown XLS 1500
Crown XLS 1002
Crown XTI 4000
Dbx 231
Mackie ProFX12
dbx pa2
2 Titan 39 16" slims w/3012lf
Windmill
Re: Beta 8a damage
#2 Post by Windmill » Tue Nov 13, 2018 10:15 pm
Also is there a test I can run to see if both drivers are operating the same?
2 WH 6 panel mount
2 WH 8 panel mount
Crown XLS 1500
Crown XLS 1002
Crown XTI 4000
Dbx 231
Mackie ProFX12
dbx pa2
J_Dunavin
Re: Beta 8a damage
#3 Post by J_Dunavin » Wed Nov 14, 2018 8:20 am
I think you’ll be ok.
Just go through the break in procedure and slowly bring on the voltage.
If there’s an issue, that should reveal it.
ACUA
Re: Beta 8a damage
#4 Post by ACUA » Wed Nov 14, 2018 8:29 am
I say, if the cone is not torn run it. if it is torn, use shoe goo, or fabric glue or some kind of silicone. Parts express has some good speaker repair gear. Play both free air and listen then if you can’t tell them apart your probably good to go.
Advanced concepts underground audio
Windmill
Re: Beta 8a damage
#5 Post by Windmill » Wed Nov 14, 2018 6:36 pm
Thanks guys. I will check them out.
Steve
2 WH 6 panel mount
2 WH 8 panel mount
Crown XLS 1500
Crown XLS 1002
Crown XTI 4000
Dbx 231
Mackie ProFX12
dbx pa2
Hakeca
Re: Beta 8a damage
#6 Post by Hakeca » Sat Dec 22, 2018 3:55 am
Thank you for this answer! I had the same issue!
J_Dunavin
Re: Beta 8a damage
#7 Post by J_Dunavin » Sat Dec 22, 2018 4:14 pm
So did everything check out ok?
Windmill
Re: Beta 8a damage
#8 Post by Windmill » Mon Nov 18, 2019 7:35 am
The speakers are now loaded in the w8’s and they sound just fine. I think the damage was just cosmetic.
2 WH 6 panel mount
2 WH 8 panel mount
Crown XLS 1500
Crown XLS 1002
Crown XTI 4000
Dbx 231
Mackie ProFX12
dbx pa2
