Wedgehorn 8 with CD
High output and wide dispersion without feedback.
Svartrose
Wedgehorn 8 with CD
#1 Post by Svartrose » Fri Oct 20, 2017 1:20 pm
Helle there,
I know that this is not a "follow the plan" question, but I'm not scared to ask :) I know that this option has less dispersion and that it costs more. I'm just wondering if it can be done and if there are advantages.
Is it possible to make a wedgehorn 8 with a compression driver and and factory horn like these:
http://www.eminence.com/speakers/hornfl ... odel=H290S
http://www.eminence.com/speakers/hornfl ... odel=BH410
What are the problems to expect? Do you have to place the horn vertical or horizontal? Will the sound from the woofer come thru?
Here's a sketchup drawing. If you want to see other angles, I can make them.
Re: Wedgehorn 8 with CD
#2 Post by Bill Fitzmaurice » Fri Oct 20, 2017 3:17 pm
Svartrose wrote: I'm just wondering ...if there are advantages.
If there were it would be an option. The use of compression horns is one of the main faults with commercial wedge monitors.
Svartrose
#3 Post by Svartrose » Sat Oct 21, 2017 2:07 am
Because of there dispersion?
