Passive Crossover questions
Posted: Sun Sep 12, 2021 3:04 pm
by J_Dunavin
I Bi-Amped my DRs even though they had Piezo arrays, not for performance gains, but I liked to turn down the gain on them.
For simplicity sake (one less amp to haul around) I'm wiring my new Otop8s (CD not piezo this time) with a passive, BUT I want the ability to bi amp in the future, should I feel the itch to do so.
I'm sure this wouldn't normally be recommended, but will this work? I've seen other commercial cabs with a bi-amp and normal inputs...
Was also thinking about adding a Zobel filter to the mids? Probably not recommended if Bill didn't put it in the plans...
And was also thinking about a fixed L-Pad for the highs? I suppose the answer to that would be to just EQ down the highs if they are too much?
Thanks for letting my kick the can around....
Re: Passive Crossover questions
Posted: Sun Sep 12, 2021 3:43 pm
On the NL4 for the passive - you'd only have two wires coming into the crossover (full range).
Posted: Sun Sep 12, 2021 3:47 pm
by J_Dunavin
ah yes.
Now I can plug a 2 pole speakon cable into a 4 pole jack, but not the other way around, right?
Posted: Sun Sep 12, 2021 4:39 pm
J_Dunavin wrote: ↑Sun Sep 12, 2021 3:47 pm
ah yes.
Yes.....always use the 4 pole jack and either the NL4 or NL2.....stay away from the old 2 pole jacks and plugs. Those suck....
https://www.parts-express.com/Neutrik-N ... nt-092-052
https://www.parts-express.com/Neutrik-N ... nt-092-198
Posted: Sun Sep 12, 2021 11:19 pm
by Seth
J_Dunavin wrote: ↑Sun Sep 12, 2021 3:04 pm
I'm fairly certain you'll need to put a switch in that isolates the crossover from at least one of the drivers when in bi-amp mode. Otherwise, the two amps will be connected through the crossover circuits.
On second thought, you might be able to just put a switch on the input side of the crossovers that simply disconnects the inputs of the crossovers from each other. But, I have no idea whether the crossover circuits would alter the sound by just having their outputs connected to the speakers or not. If not, I think this would be the simplest solution.
Posted: Mon Sep 13, 2021 4:28 am
by Rune Bivrin
For any crossover steeper than 6dB/octave, you'll need to disconnect the drivers from the crossover. Otherwise, the amps will "see" the drivers in parallel with extra components, which may cause substantial problems.
Posted: Mon Sep 13, 2021 6:36 am
by J_Dunavin
Rune Bivrin wrote: ↑Mon Sep 13, 2021 4:28 am
Ahhh yes I didn’t think about components being parallel across the coil of the speakers.
Thanks for the input guys!
