Hi
I have an Avitar 4x10 cabinet with Eminence Lite speakers but no name applied, just the eminence logo. Is there a tag or number printed on the cone perhaps that could be used to identify the TS specs. I want to repurpose the speakers as I never use the cabinet anymore.
Thanks in advance.
Re: How to get Eminence speaker specs?
Posted: Fri Nov 06, 2020 10:00 am
Look for a paper sticker on the outside of the magnet. That's typically where there is a model number. It's not the one you see on the Eminence website but they can cross reference the OEM number to a retail model.
Posted: Fri Nov 06, 2020 10:12 am
If it's an OEM driver chances are you can't get the specs, those being proprietary to the OEM customer.
Posted: Fri Nov 06, 2020 11:08 am
by T_Gowan
If I cant get the specs is there any way of "guessing" what BF cab it might perform well in. Using the existing box volume, porting etc.
Posted: Fri Nov 06, 2020 11:12 am
If they're Eminence tens they're not going to be so far off that they can't be used in any of the ten loaded cabs other than subs. But they may be 4 or 16 ohm, you'd have to measure the DCR to be sure. DCR is about 0.7 times the impedance.
Posted: Fri Nov 06, 2020 12:50 pm
by Seth
T_Gowan wrote: ↑Fri Nov 06, 2020 11:08 am
Well just got my set of BF plans, the Jack10 Lite looks intriguing. First plan is for expandable bass rig but will no doubt us it full range at some point so full tweeter array will be used. As I have 4 10s I'm planning on 4 cabs. will it be advisable to do the lower melded and the upper straight array?
This is all in the future as there are no gigs on the calendar and I have a major kitchen-dinning room reno on the go( 4 year plan ) don't tell my wife that.
Posted: Wed Nov 25, 2020 11:24 am
You'd do melded lower and straight upper in a PA rig.
Posted: Wed Nov 25, 2020 11:57 pm
T_Gowan wrote: ↑Wed Nov 25, 2020 10:35 am
I can see using 2 for my portable bass rig, been using an SWR 210. But I have an Avitar 410 that I never use with Eminence lites. So thought I would just repurpose the 10s. You know I have to build something and its been so long.lol
