How to get Eminence speaker specs?
T_Gowan
#1 Post by T_Gowan »
Hi
I have an Avitar 4x10 cabinet with Eminence Lite speakers but no name applied, just the eminence logo. Is there a tag or number printed on the cone perhaps that could be used to identify the TS specs. I want to repurpose the speakers as I never use the cabinet anymore.
Thanks in advance.
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
Re: How to get Eminence speaker specs?
#2 Post by Bruce Weldy »
Look for a paper sticker on the outside of the magnet. That's typically where there is a model number. It's not the one you see on the Eminence website but they can cross reference the OEM number to a retail model.
#3 Post by Bill Fitzmaurice »
If it's an OEM driver chances are you can't get the specs, those being proprietary to the OEM customer.
T_Gowan
#4 Post by T_Gowan »
If I cant get the specs is there any way of "guessing" what BF cab it might perform well in. Using the existing box volume, porting etc.
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
#5 Post by Bill Fitzmaurice »
If they're Eminence tens they're not going to be so far off that they can't be used in any of the ten loaded cabs other than subs. But they may be 4 or 16 ohm, you'd have to measure the DCR to be sure. DCR is about 0.7 times the impedance.
#6 Post by Seth »
T_Gowan wrote: Fri Nov 06, 2020 11:08 am If I cant get the specs is there any way of "guessing" what BF cab it might perform well in. Using the existing box volume, porting etc.
Dayton Audio DATS V3 Computer Based Speaker & Audio Component Test System
T_Gowan
#7 Post by T_Gowan »
Well just got my set of BF plans, the Jack10 Lite looks intriguing. First plan is for expandable bass rig but will no doubt us it full range at some point so full tweeter array will be used. As I have 4 10s I'm planning on 4 cabs. will it be advisable to do the lower melded and the upper straight array?
This is all in the future as there are no gigs on the calendar and I have a major kitchen-dinning room reno on the go( 4 year plan ) don't tell my wife that.
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
#8 Post by Bill Fitzmaurice »
You'd do melded lower and straight upper in a PA rig.
#9 Post by Tom Smit »
T_Gowan wrote: Wed Nov 25, 2020 10:35 am Well just got my set of BF plans, the Jack10 Lite looks intriguing. First plan is for expandable bass rig but will no doubt us it full range at some point so full tweeter array will be used. As I have 4 10s I'm planning on 4 cabs. will it be advisable to do the lower melded and the upper straight array?
Are you going to build a "tower of power" rig?
Remember this one? viewtopic.php?f=13&t=8973&p=89370#p89370
T_Gowan
#10 Post by T_Gowan »
I can see using 2 for my portable bass rig, been using an SWR 210. But I have an Avitar 410 that I never use with Eminence lites. So thought I would just repurpose the 10s. You know I have to build something and its been so long.lol
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
