Ok we are finally rebuilding our home after our house flooded on June 21st. I am taking advantage and running wires behind our viewing wall in order to move HT equipment to a closet under stairs that are off to the right side of living room. Attached is a pic of my living room. My wife would like no wires showing and her preference would be no speakers showing as well. I told her that the only wires will be from wall to speakers.
So I ran speaker 2 cables(sub and lt channel) to the left, HDMI and speaker to center and speaker cable to right side of screen. Center channel will probably sit on a stand or wall mounted with the projector transmitter.
I was thinking of speak on connectors mounted on a wall plate for easy hookup,, but I was hoping maybe someone had something that was nicer looking
Thanks in advance,
Oscar
Looking for WAF on wall plates
- BrentEvans
Re: Looking for WAF on wall plates
Speakon is a bit much for home Theater. Banana terminals or binding posts are more than sufficient.
https://www.parts-express.com/audtek-el ... t--261-352
Thanks Brent. I think I have seen those at Home Depot.
Thanks
Thanks
- James Champer
This is what you'l need behind your receiver for 5.1.
https://www.monoprice.com/product?p_id= ... P4EALw_wcB
Thanks James,James Champer wrote: ↑Sat Aug 04, 2018 9:16 pm This is what you'l need behind your receiver for 5.1.
I had not thought about the connection in the closet, but that will make it look great and clean, Wish it had HDMI as well.
- BrentEvans
https://www.parts-express.com/wired-hom ... e--300-617
You can build any combo you want with decora inserts and keystones, though.
This company is local to me, have been using their stuff for years with no problems.
https://www.firefold.com/home-theater/wall-plates
