making speakon cables
I was just wondering what type of cord do you use for making the cables, I found a deal on 12/2 sjoow cord like what you would use on extension cords, will this work well? http://www.cshincorporated.com/product_ ... s_id=11830 also I am so new to live sound (first mixer on the way) do most of you keep your amp rack close to the stage and run shorter speaker wires or with the mixer out front with longer wires? thanks for the help/advice in advance.
Re: making speakon cables
Neoprene rubber makes winding up 100ft. of 12GA+ cable easier than PVC. Similar cable @ P.E. is priced ~33% higher.
EDIT: I thought it was 12ga. but it is 14ga. May want to be more specific on the length and power requirements.
T39 - Dual BP102 23"
AutoTuba
J12 x 2 - Deltalite 2512
O12 - Dual BP102
AutoTuba
O12 - Dual BP102
For the budget minded. Note: there is only 91' on a roll.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... K:MEWAX:IT
Have you used this? If so what is the jacket material like, thick? Strong?netwerks wrote:For the budget minded. Note: there is only 91' on a roll.
I've bought 4 rolls of it and the jacket is very thick and strong and the wire inside fits tightly in the speakon connectors.gilscales wrote:Have you used this? If so what is the jacket material like, thick? Strong?netwerks wrote:For the budget minded. Note: there is only 91' on a roll.
As Bill says "copper is copper"
Signal losses at line level into high impedance loads are slight, signal losses at speaker level into low impedance loads are major, so keep the speaker cabling as short as possible. And copper is copper.
