What do you mean by "compression" and "rarefaction"?Landl.livesound wrote:Hey Stan,
If air is "basically incompressible" with what we are dealing with, isn't it that sound happens because of the compression and rarefaction of the air molecules?
Take Care!
Phil
It is true that sound waves in air are more like a compression wave than like a wave on the surface of a body of water. It is also true that sound waves are generally better thought of as a "vibration" than a "pressure wave".
At a molecular level, the molecules are constantly and randomly colliding with each other. At this level, the molecules are not "uniformly distributed" and there is not really a concept of "density" as you are likely thinking of it - there are discrete particles in close proximity. As such, there is no compression or rarefaction (both of which are effectively changes in local uniform density).
At a "10,000 ft" level, still air is an incompressible, uniform, continuous fluid. At this level, the "sound wave" will pass through the local area without altering the local conditions before or after the wave....including the local density. Given that, it is not generally helpful to think of the propagation of a sound wave to be because of compression or rarefaction.
Once you get into "compressible aerodynamics" then compression and rarefaction are factors that need to be considered. You might have heard this kind of aerodynamics referred to as "sonic booms." Until the local speed is more than Mach 0.3...compression is not a serious factor.
If there were one wave, one up and one down....then it would be helpful to think of the compression and rarefaction that surrounds that wave. But, since sound is generally composed of a continuous series of waves of various wavelength, amplitude, frequency, and direction...I find that the "vibration" model is generally yields a better overall understanding.
