I want to run both a guitar signal, and a vocal signal through a power amp. Can one stereo power amp send the guitar signal to a guitar cab and the vocal signal to a PA cab? or will I end up with both signals going to both cabinets.
Thanks.
Stereo Power Amps: different signals to different speakers?
"GOT QUESTIONS? NEED HELP?
Chat with other builders on the Forum. You can benefit from the experience of literally hundreds of builders/owners to decide which speakers are right for you, and how to build them. "
Re: Stereo Power Amps: different signals to different speakers?
Gonna need more info. I.E. model of amp? Are you plugging directly in to the amp?Impedance of both cabs?
4 20" T39(built)
2 WH8(built)
3 WH10(own)
4 DR200(own)
1 Jack 12(built)
SAC 24 Channel Mixer
SAW STUDIO Recording
I will be plugging into a PreSonus Firestudio for the vocal preamp and a Sansamp California for the guitar preamp. I was thinking 8 ohm cabinets, but that's a variable as I haven't built them yet. I'm just wondering if two signals can be kept totally separate by a stereo power amp.
As long as it has separate inputs for each channel. But, we need more info.
I was thinking one of these: http://www.qscaudio.com/products/amps/rmx/rmx.htm
into an omni212 (guitar, no tweeter) and two daisy-chained wedgehorns (vocals)
Usually you'd have at least a small mixer in the middle there. What are you trying to accomplish?ryansalmond wrote:I want to run both a guitar signal, and a vocal signal through a power amp. Can one stereo power amp send the guitar signal to a guitar cab and the vocal signal to a PA cab? or will I end up with both signals going to both cabinets.
Thanks.
+1 : add a small mixer before the amp. Pan guitar to one side, and vocals to the other side. Just make sure they are always panned appropriately before you turn on/up. You get much more control using a mixer instead of just plugging strain in.
