Page 2 of 4
Re: On Board Amp
Posted: Fri Mar 01, 2019 4:38 pm
Like this...
Re: On Board Amp
Posted: Fri Mar 01, 2019 5:59 pm
by mino00
I bought crossover's built by speakerhardware on ly + and - input so how do I wire high & low frequency from the amp to this cross over ? I am totally confuse .
Thanks
Re: On Board Amp
Posted: Fri Mar 01, 2019 6:08 pm
You don't use a crossover. The woofer is powered by the low frequency amp, the tweeters are powered by the high frequency amp. You may get somewhat better results if you have a piezo array using the high pass filter in the plans.
Re: On Board Amp
Posted: Fri Mar 01, 2019 8:33 pm
by mino00
Thank you very much I understand now
Re: On Board Amp
Posted: Tue Aug 11, 2020 8:47 am
by tizlaney
Bill, I am looking to use a SRM450 plate amp in a set of SLA PRO 4X6.
The back brackets for the center support would be in the way of the amp installation. How would you recommend modifying? I would prefer the amp not be side mounted.
The back panel is sufficient in size to allow installation if the two supports are eliminated or modified.
Re: On Board Amp
Posted: Tue Aug 11, 2020 9:06 am
No link.
Re: On Board Amp
Posted: Tue Aug 11, 2020 10:07 am
by tizlaney
Sorry about that.
https://lase.us/shop?olsPage=products%2 ... aker-w-dsp
I have used this to fix a broken Mackie 450 and it is a pretty close match to the 450 amp, plus it adds DSP.
Re: On Board Amp
Posted: Tue Aug 11, 2020 10:29 am
You could eliminate the center support and instead use 1x2 braces to connect the front to the back and the sides to each other spaced to avoid the amp.
Re: On Board Amp
Posted: Tue Sep 08, 2020 5:14 am
by Paddlsonic
i am thinking of building 2 x tuba30 and 2x DR280 or something similar.
Could one of these Dayton units power 1 x tuba and 1 x dr280? in which case i'd buy 2 of these.
Or could it power 2 x tuba on one unit and 2 x DR280 on the other unit?
If so which is the better config?
Or have i totally missed the mark trying to power up this config using this unit?
cheers
Re: On Board Amp
Posted: Tue Sep 08, 2020 7:30 am
It's only 600 watts at 4 ohms.....that's not going to drive the Tubas with premium speakers to their potential. But, you have a few other issues. 2 Tuba 30s aren't going to keep up with 2 DR280s.
And based on your question, I'd assume you were planning to split the subs which isn't a good idea.
You might want to start a new thread telling us what you are trying to accomplish and we can help you get there.
Re: On Board Amp
Posted: Tue Sep 08, 2020 6:57 pm
by Paddlsonic
Thanks Bruce.
As you saw in the other thread i'm still working on config but your advice about the DR200's sounds like a good balance.
Don't need to split the subs.
could i run one unit for each sub and another for both the DR200's? Will that drive everything to potential?
I'm obviously new to this, but i like these Dayton units as everything you need seems to be built in and i like the software.
Unless there's another product similar you can recommend.
cheers
Re: On Board Amp
Posted: Tue Sep 08, 2020 9:17 pm
I recommend forgetting about the plate amps for this kind of system. Get a driverack and either two amps or a 4 channel amp capable of about 500 watts at 8 ohms. Put 'em in a small rack. Less cables, good limiter, and EQ in the driverack to set it all up.
Re: On Board Amp
Posted: Tue Sep 08, 2020 9:23 pm
One of those plate amps could drive a pair of DR200, but you don't want to use them for subs. One of these would handle a pair of T30:
https://www.parts-express.com/b-52-actp ... --299-2336
Re: On Board Amp
Posted: Wed Sep 09, 2020 3:59 am
by Paddlsonic
Thanks guys , really appreciate all the advice
Re: On Board Amp
Posted: Wed Sep 23, 2020 8:38 am
by Paddlsonic
Am i right in thinking this product
https://www.parts-express.com/b-52-actp ... --299-2336 , has a set crossover at 100hz?
i was thinking of using this sub amp on my subs and Dayton full range amp on the DR200 tops with the delta pro 8a . It seems like the DR's drop off a bit above that, around 130hz? I guess i need a sub amp that has variable crossover to cover the 100-130hz range??
or am not right in thinking that?
cheers
