Factor PA2000
Posted: Wed Oct 25, 2017 10:57 pm
My work updated all the A/V gear and was giving the old stuff away. Snagged this and it seems like should run a pair of Otop12's just fine or the a pair of T30's okay.
Definitely not looking a gift horse in the mouth.... It should play nicely with my 2 Crown XLS2500's for the 2 Otop's and soon 4 T30's.
Got also another Factor PA1000 as well and some wireless mics.
Thoughts?
http://www.mcssl.com/store/factorelectr ... b1a71726a6
Specifications:
Frequency Response: 20 Hz – 20 kHz (+/- 1dB)
Signal-to-Noise Ratio: > 100 dB A-weighted
THD+N <0.1%
Voltage Gain 37dB +/- 0.5dB
Input Impedance: 20 kΩ (bal) 10 KΩ (un-bal)
Damping Factor >500
Power Rating:
600W per channel into 8 ohm stereo loads
1000W per channel into 4 ohm stereo loads
1500W per channel into 2 ohm stereo loads
2000W bridged mono into 8 ohms
3000W bridged mono into 4 ohms
Dimensions: (W x H x D):19”/482mm 3.5”/88mm 17”/432mm
Weight: 20.5lbs / 9.3kgs
Features:
2 Ohm stable operation
Variable speed ultra-quiet cooling fan
Power ready, Signal Present, Clip & Protect
LED indicators for each channel
Front panel level controls
Switched soft knee clip limiters
Switchable stereo, parallel and bridge mode
Soft start in-rush current limiting
Input via 1/4’’TRS and XLR connectors
Speaker outputs via Speakon® connectors
Speaker outputs via two pairs of heavy duty binding posts
Thoughts?
Specifications:
THD+N <0.1%
Damping Factor >500
Power Rating:
Features:
