Amplifier advice
Posted: Thu Jun 29, 2017 8:41 am
Looking for an amplifier selection gut check.
I am in the home stretch of completing 2 T48 234(2’x3’x4’) with 2 3015LF in each Titan. Currently the amp rack is full of Crown amps. The 1 K2 is not enough to run the new Titan’s.
I am thinking that the Crown XLi 3500 is a good choice. I would run the 3015LF in parallel in one Titan into one channel and do the same with the other Titan in the other channel. That would be 900W @ 4Ω and that amp is rated at 1350W @ 4Ω. That would allow me 50% overhead so the amp is not working so hard all the time. If for some reason that turns out to not be short on power, I could get another amp and run all 4 one-to-one. That would be 1000W @ 8Ω with 122% overhead. More than enough. The venue is not a night club, rather a house of worship.
Naturally if there is a better choice I am open to it.
For limiting and crossover I am not really sure which of these will give me the best bang for the buck. Is it the DCX2496 or the Drive Rack PA2?
