Looking for an amp recommendation
zpro
Re: Looking for an amp recommendation
#46 Post by zpro »
Bump.
Nobody can give me some advice on this? :?:
Thanks,
Z
#47 Post by Grant Bunter »
zpro wrote:Bump.
Thanks,
Z
Do you mean adding bluetooth?
Because it's adding more to the chain, I would leave it out initially.
Get everything else sorted first...
zpro
#48 Post by zpro »
Thanks Grant Bunter, yes I was referring to the fact that I still don't know whether it is possible to use a digital bluetooth receiver with the minidsp and if so, which one.
I want to have bluetooth setup as soon as possible because the minidsp will be located in a location that is not useable for a wired connection (i.e. usb)
If anyone can direct me I would truly appreciate it!
Z
#49 Post by Chris_Allen »
What version of Bluetooth does your Macbook support?
I know the later versions were considerably better and not having to compress the audio anywhere near as much. I would get the latest BT version (4.0?) on your receiver then at least you don't have to upgrade it should you end up getting a 4.0 transmitter.
zpro
#50 Post by zpro »
It does have bluetooth 4.0 already built in.
Any models you would recommend specifically for use in my scenario?
Many thanks!
Z
zpro
#51 Post by zpro »
Decided to go with apple's airport express A1392. Awesome little device! Also avoids the problem of bluetooth compression.
It outputs digital using a combined mini TOSLINK and conventional 3.5mm port, both in one...
Thanks! :D
