build a voltmeter into plate amp
Is this amp OK?
thommio
#1 Post by thommio »
So i recently bought a 300W plate amp for my TableTuba and i am going to build it into a wooden case. My question is: Can i build-in an analoge voltmeter directly parallel to the speaker output?
Voltmeter:
http://www.ebay.nl/itm/UPDATED-Analog-V ... 27f67293c5
Amplifier:
https://www.conrad.nl/nl/inbouw-verster ... 01044.html
Woofer:
JBL GTO804
CoronaOperator
Re: build a voltmeter into plate amp
#2 Post by CoronaOperator »
Why not, however you will need an AC volt meter. The meter you listed is DC.
thommio
#3 Post by thommio »
Thanks for your reply. Thanks for reminding me about the AC, totally forgot about that :lol:
Jake Jarmon
#4 Post by Jake Jarmon »
2 - T24 24" BP102 "Twinning"
2 - OT112 Delta Pro 12 Melded Array **In Progress**
thommio
#5 Post by thommio »
And why should i use that instead of just buying an AC voltmeter and connect it parallel to the speaker output?
