Quick question on Voltage, Amp and Signal
TheCesar
#1 Post by TheCesar »
You can calculate and test your amplifiers to limit them, if you don't have some kind of limiter in your PA rig. V=squareroot(W x R). To find the AC voltage for the maximum output you require from your amp, take the watts, say 400, multiply by the resistance of your speakers, say 8 ohms, then take the square root of the result.
V=sqrt(400x8). V=56volts. That would be 400watts into an 8ohm load. Heres a link to calculators to do this in various ways. http://www.csgnetwork.com/ohmslaw2.html
Most amplifiers are rated with with a 1k signal. Hook it up to your pa. Unhook your speakers. Drive the pa with the 1k tone up to the 0db level on your meters. Put a voltmeter set to read AC on the amp, neg on neg, pos on positive. It will read the output voltage of your amplifier.
Quick question on Voltage, Amp and Signal:
I'm trying to do the calculation of the vols out of the amp im using for subs this is the setup:
PC to mixer
mixer to crossover dbx234xs
crossover low output to Amp EP2500.
The question is: should the signal from my pc be 1K or should it be lower?
Thank you!
sine143
Re: Quick question on Voltage, Amp and Signal
#2 Post by sine143 »
you can verify (before crossover) with a 1khz tone straight to the amp.
if you are trying to test voltage out for subwoofer use (post crossover) and trying to set the limiter, us a 60hz tone
TheCesar
#3 Post by TheCesar »
Perfect Thank you!!!!!
