byacey wrote:I don't think you should be seeing 400KHz @ 0.6V on the speaker terminals. What you're seeing may be coupled through the power supply grounds between the amp and the scope, or a ground loop. Often switching supplies will kick some noise back onto the AC line despite the filters they use to prevent this.
I can't hear 400KHz, although some self professed audiofools will claim they can.
I doubt there is a mammal alive that could hear 400Khz! I tried lifting the earth connection on the amp and the scope. No difference to report.
byacey wrote:A good power amp introduces very little noise other than what is introduced by the line level gear via the inputs.
When I first pulled the amp out of the box I noticed one of the rack mounting "wings" at the rear had been dinged and then I noticed the box had a slightly flat corner. Perhaps this might have something to do with it? Got dropped. Something awry?
So I suppose I will contact tech support Monday and ask if the ripple & hiss is normal. If it is I'll return it and chalk this one up to experience. If not I'll exchange it and report back here.
The question is what amplifier(s) could I get that would satisfy the audiofile in me. I'm not going to all this trouble for OKish results!!
Requirements are as follows: NO HISS! Suitable for a pair of SLA's (Not Pro's) and one of the home based sub woofers. Haven't settled on a sub yet but I expect I'll build a Tuba HT to play with. Must sound fan-bleeding-tastic. Primary task will be for playing vinyl with some home theatre duties looming on the horizon when I'll turn the system into 5.1.
