Crown amps with issues
Is this amp OK?
Windmill
#1 Post by Windmill » Sun Mar 19, 2017 8:37 pm
So recently I met with a restaurant owner who just bought a place and is renovating it. They are selling off the old pa equipment that came with the place.
1 xti 2000
2 xti 4000
and a Machro Tech
and eaw speakers
I was interested in one of the 2000's for my 2 t39s. On close scrutiny it appeared that all three of the xti's had been used in an unorthodox way; the power buttons had all gone missing so someone unscrewed the right side of the front panels, removed the right finger hold thingy and this made it so you could pry forward the front panel and reach inside to press the inner power button. yeesh.
I took one of the 4000's home to test it and it seems to be in good working order, display and everything despite the missing power button/finger hook, The owner agreed to $225 for it. Now for the 2000, it has no display. The display is lit but I can't see any characters, or maybe only faintly. Maybe only a loose wire? I doubt it could be sold in its current condition, ya can't tell what preset your on. has any one had to replace the whole mother board on that front panel? I offered to post up a question to you guys to get ideas.
I might take the other 4000 if it seems to be working ok. I do diy fixits on amps but I am no electronics wizard by a long shot. Just looking for loose stuff, solder a repair and clean things up.
Thanks for the input.
Own a pair of jack 10's from c'list with Eminence Beta 10A's
Wedge Horn 6's my build
Crown XLS 1500
Crown XLS 1002
Mackie ProFX12
dbx pa2
Titan 39 16" pair slims built but as yet untested.
Re: Crown amps with issues
#2 Post by Bruce Weldy » Sun Mar 19, 2017 9:33 pm
Often the display malfunction is a case of the ribbon cable needing to be cleaned and reset. If you can buy it really cheap - take a chance on that being the fix.
If not, then offer to try and fix it before buying it - you can't make any changes to the setup without the screen.
Just locate the ribbon cable and take it off. Use some denatured alcohol on a Q-tip to clean off the connector on the board. Then shoot it with some DeOxit 5 if you have some. Sometimes just resetting the cable fixes it.
If that doesn't work - pass on it.
6 - T39 4-25" 2-22" 3012LF
4 - OT12 2512 Melded/NSD2005
Windmill
#3 Post by Windmill » Sun Mar 19, 2017 10:18 pm
Thanks! I'll give it a shot.
Crown XLS 1500
Crown XLS 1002
Mackie ProFX12
dbx pa2
#4 Post by DJPhatman » Sun Mar 19, 2017 11:32 pm
I had XTi's in my setup. Just leave the power buttons in the "On" position, and don't touch them again. Using a Windows computer, download HiQnet Band Manager. Plug the amps into a USB cord connected to the computer running Band Manager, 1 at a time, and check all the settings through the software. It's so much easier to do than through the front controls. And who cares about the front screen. Probably got broke by some sausage-fingered dude trying to hit the power button.
