6 1/2" driver mounting in AT/TAT
#1 Post by Radian » Tue Jul 18, 2017 2:01 pm
Afternoon Bill, when using dual Tang Band W6's in an AT or TAT, what's your guidance on placement when mounting the driver(s) to the baffle?
Still use edge of the driver(s) the stated distance to panel 4?
or
Line up the smaller drivers along where the center line of the 8" driver would normally be?
Re: 6 1/2" driver mounting in AT/TAT
#2 Post by Bill Fitzmaurice » Tue Jul 18, 2017 6:46 pm
Keep the same frame distance to panel 4.
#3 Post by Radian » Wed Jul 19, 2017 1:50 am
Wilco. Image
#4 Post by DJPhatman » Wed Jul 19, 2017 2:09 pm
Radian, you trying out the drivers, a theory, or just making it for the helluvit?
:mrgreen: :ugeek:
#5 Post by Radian » Wed Jul 19, 2017 10:25 pm
Using the drivers. 8)
Padde298
#6 Post by Padde298 » Tue Sep 19, 2017 9:05 am
How did this pan out? :hyper: Do you have any build pics?
2 x TAT
#7 Post by Radian » Tue Sep 19, 2017 8:50 pm
No build pics yet, as I'm well into SLA Pro construction at the moment. This project is third on my cab "to-do" list.
They will be for our 2ch system, which consists of an OPPO BDP-103 patched to an NAD C390DD and PWR-ICE250 driving a pair of Frazier CAT40 and what will be a pair of Auto Tubas, loaded with these W6 drivers.
I already tested the setup with my other pair of MCM loaded AT's to see if they'd perform as required....which they did naturally. I suspect these will sound simply fantastic for this application.
#8 Post by Radian » Sun Oct 01, 2017 1:34 pm
The test drive, in order to see (and most importantly to listen) if the Auto Tuba and Frazier would play well together, at all, in this arrangement. As I mentioned before, the result was overwhelmingly positive. 8)
