SLA Pro Dampening
Tedward
SLA Pro Dampening
#1 Post by Tedward » Sun Aug 21, 2016 6:04 pm
Started a pair of SLA Pro's and I 'm ready for the carpet felt. This stuff is hard to come by in my area (Southern California). Seams the foam is what is used around here. Can I use 1/2" carpet foam or I have some 1 1/2" convoluted foam?
Tedward
Re: SLA Pro Dampening
#2 Post by Bill Fitzmaurice » Sun Aug 21, 2016 6:35 pm
Carpet foam isn't always open celled. Mattress foam is OK, but the advantage to felt carpet padding is it's so thin, much easier to work with in the small confines of the SLA. California or not I can't believe carpet stores don't have felt padding. I wouldn't want foam padding in my McMansion. 8)
Tedward
#3 Post by Tedward » Sun Aug 21, 2016 10:54 pm
Thanks Bill, kinda disappointing. I can special order it from HD or Lowes but don't need yards of it. Since I have plenty of matters padding I'll use that.
Tedward
#4 Post by Bill Fitzmaurice » Mon Aug 22, 2016 6:57 am
Tedward wrote:I can special order it from HD or Lowes but don't need yards of it.
Try a real carpet store. Just like with plywood big boxes don't carry the good stuff, only the cheap stuff.
garychelette
#5 Post by garychelette » Fri Oct 14, 2016 5:43 pm
Texas uses the foam padding for carpet. I have never seen "felt" padding here.
I'm thinking giving Acry-Tech Acoust-X a try.
#6 Post by Bill Fitzmaurice » Fri Oct 14, 2016 9:00 pm
garychelette wrote: I'm thinking giving Acry-Tech Acoust-X a try.
It won't work.
#7 Post by CoronaOperator » Sat Oct 15, 2016 2:38 am
That stuff is used to dampen the ringing of thin sheet metal in car doors, plastic body panels in cars, etc. It works similar to holding a bell or cymbal with your hand as opposed to letting it ring out. It isn't meant to damp the actual sound wave propagating though the air. It is essentially a paint on version of the following:
CosmicTech
#8 Post by CosmicTech » Mon Mar 13, 2017 4:50 pm
What about jute carpet padding that is used in automobiles? I've seen that at 1/2" thick. It seems to be reasonably priced too.
#9 Post by Bill Fitzmaurice » Mon Mar 13, 2017 8:53 pm
Jute should be fine. It's basically the plant based version of felt, which is wool.
