DEQ2496 on mixer insert
laits
#1 Post by laits » Tue Jan 12, 2016 6:54 pm
Can I run the DEQ2496 on my mixer main inserts, same as an analog eq? Can i still use the rta feature? How do I wire up the cables?
Built 2-OT12 (3012HO); 2-T39 22" (3012LF); 2-T39 16" (3012LF);
2-J12 (DL2512); 2-W8 (Beta 8A)
BrentEvans
Re: DEQ2496 on mixer insert
#2 Post by BrentEvans » Tue Jan 12, 2016 8:44 pm
You could, but why not just run it in line?
laits
#3 Post by laits » Tue Jan 12, 2016 11:31 pm
I would like to be able to just look at my mixer output meter to know if I am close to limiter hitting.
#4 Post by Bruce Weldy » Tue Jan 12, 2016 11:59 pm
laits wrote:I would like to be able to just look at my mixer output meter to know if I am close to limiter hitting.
Use the proper technique to set the limiter and you'll be able to do that.
6 - T39 4-25" 2-22" 3012LF
4 - OT12 2512 Melded/NSD2005
dswpro
#5 Post by dswpro » Wed Jan 13, 2016 9:20 am
Since my DCX lives at my amp rack near my stacks, I can never see it during a gig, so I rely on my console meter to let me know if I am at or near the system limit. When I setup the DCX, I use an oscillator and set my mixer output to a visually noticeable point. I use the third yellow light on my master output meter, but you can use any convenient setting which does not overload the DCX input. Then I set the DCX limiter to protect my speakers and keep any higher console output from passing into my amps. I also put a 2:1 compression on my console output ( I use an X32 ) about 6 db below that point so I can hear my mix start to squeeze before I hit the DCX limiters. Then while operating my board I easily can see if I have any system headroom left, and don't have to rely on seeing the DCX. Three years of gigs now with my T39s and Otops and I've never blown a driver.
laits
#6 Post by laits » Wed Jan 13, 2016 9:45 am
That is exactly what I want to be able to do. Know if I am near limiting by looking at mixer output meter. I was thinking if the DEQ was in-line (not using mixer master insert) then if I made an eq bump to account for different rooms, then the mixer output meter and DCX limit light would no longer be in sync. Am I understanding this correctly?
#7 Post by Bruce Weldy » Wed Jan 13, 2016 9:56 am
laits wrote:That is exactly what I want to be able to do. Know if I am near limiting by looking at mixer output meter. I was thinking if the DEQ was in-line (not using mixer master insert) then if I made an eq bump to account for different rooms, then the mixer output meter and DCX limit light would no longer be in sync. Am I understanding this correctly?
That last thing in line is your limiter....so, the other moves you make further up the line like EQ won't affect your set limit.
While you should get your limiter set properly, you are really overthinking this. Hard limit the subs to protect them. If you do it right, you'll know when you are approaching the limiter with your lights. But, don't get too worried about the lights - use your ears....if it starts to sound distorted - turn it down.
#8 Post by Grant Bunter » Wed Jan 13, 2016 4:17 pm
The DEQ2496 has nothing at all to do with limiting.
That's the DCX2496's job.
As Bruce has been saying, the limiter is the last controlling segment in the DCX prior to the amplifier.
So that nothing you do further up the chain changes limiting.
DR 250: x 2 (melded array) with March 2012 plans. 2 more under way with CD horn
WH8: x 3 with melded array.
#9 Post by Bruce Weldy » Wed Jan 13, 2016 11:09 pm
Grant Bunter wrote:The DEQ2496 has nothing at all to do with limiting.
Hah! I just saw the 2496 and didn't even notice the DEQ in front of it. Still don't want use it as an insert though.
laits
#10 Post by laits » Thu Jan 14, 2016 9:29 am
I shouldn't have related this question to any limiter setting, that is another topic.
What I am simply asking here is the functionality of the DEQ2496 when used in the main board output inserts. This is how I used to have my old graphic eq setup so I could see the what changes the eq was having on my overall output level from the board. I don't believe this is an uncommon way to use a graphic eq. I wanted to know if anyone had experience with using the DEQ2496 in that fashion (pros and cons).
#11 Post by Bruce Weldy » Thu Jan 14, 2016 9:47 am
laits wrote:I shouldn't have related this question to any limiter setting, that is another topic.
Actually, it's not common at all as most inserts are unbalanced. You should always try to keep a balanced signal throughout. Unbalanced signals run -10 and balanced run +4.
There is truly no reason to run an EQ that way.
You haven't mentioned what mixer you have...what are you running?
laits
#12 Post by laits » Thu Jan 14, 2016 11:35 am
Ok, got it. I will run DEQ in-line. Thanks.
I use either a mixwizard 16:2dx or soundcraft efx8.
#13 Post by Bruce Weldy » Thu Jan 14, 2016 3:31 pm
laits wrote:Ok, got it. I will run DEQ in-line. Thanks.
Those both are definitely using unbalanced inserts.....in fact, balanced inserts are pretty much unheard of...don't know that I've ever seen one...it would require a send and return jack - can't be done on a single TRS jack.
Seems I remember some old mixers that had send and return jacks for inserts.....been a long, long time ago.
#14 Post by Grant Bunter » Thu Jan 14, 2016 3:52 pm
My FOH DEQ is in line between the outputs of my Soundcraft (Spirit 8 or 16) and my DCX.
I have them in the same rack unit, one on top of the other, with very short custom made patch leads.
Over time, some have suggested connecting the two units with the AES facility, to eliminate the DA conversion on the DEQ at output, and the AD conversion on the DCX at input.
I might give it a try soon.
Inserts are unbalanced.
Also, check out your manuals, so you know for certain that your first red light on output meters for both the mixwizard and the EFX8 is actually the same value.
It's not uncommon for different manufacturers to have different reference points on the meters...
#15 Post by Bruce Weldy » Thu Jan 14, 2016 4:30 pm
True, so if you plan to use two different boards and this is really important to you, then clone over your setting and make a new setting with a different limiter setup for the other board. Name the setting in the DCX based on the board.....then you'll get the same thing every time.
But honestly, if you are riding on the edge all the time with your system so that you need to know where the absolute max is......you need more system.
