Using dmx cables for pre-amp use?
- subharmonic
Re: Using dmx cables for pre-amp use?
According to Black Box Short Haul Modems in their manuals it says that inductance caused by the shield knocks down length of runs by 1/3 with communications signals. That shoildnt be an issue for most of us since we are taking 1 vs 3 mile runs.
I need more bass
CW Mcall
I need more bass
CW Mcall
Subharmonic, is that a comparison of unshielded and shielded cable? Mic cable is after all also shielded, even if not as much as DMX cable. The difference should be less if you compare two different shielded cables, I believe?
Robin Larsson
Nzone Audio & Lights
Built so far:
2x 31.5" T48: 3015LF loaded
2x DR280: 3012HO/CD10fe loaded (bi-amped)
2x Jack 15 Lite: 3015HO loaded (Electric Bass)
Also using:
4x 27" T30: 3012LF loaded (Osse´s cabs, lives at Nzone HQ;)
Built so far:
Also using:
