Simplexx wedge drivers
tvent
#1 Post by tvent » Tue Dec 11, 2018 7:32 pm
Thinking toward the future, I may end up building some Simplexx wedges for stage monitor use.
(Yes, I know I have other projects planned - but...)
Trying to decide on whether to go with the 10 or the 12. I like that flat response of the 10, but the slightly higher and lower output of the 12 is attractive too.
Size/Weight wise, they don't look dramatically different on paper.
Oddly though, while looking over the posted specs from Eminence, the 12 has a 3.5mm Xmax where the 10 has a 5mm Xmax.
Does that sound right? Is there a typo in the specs? If this is right, would the extra 30% Xmax give the 10 any advantage?
Here's the specs if anyone wants to check them out:
http://www.eminence.com/pdf/Beta_10CX.pdf
http://www.eminence.com/pdf/Beta_12CX.pdf
Would have made more logical sense to me if it were the other way around.
Anyone have any idea what is going on with these?
Thanks,
Tim
4 x WH10 melded
4 x WH8 melded
2 x Jack15 melded
2 x Simplex 12 w/BGH-25 for Bass
1 x Simplex Tiltback (powered PPA800DSP) for Keys
2 x SLA Pro
Bought:
6 x T39 20" 3012LF loaded
Re: Simplexx wedge drivers
#2 Post by Bill Fitzmaurice » Tue Dec 11, 2018 9:51 pm
Don't compare xmax with different size drivers, compare Vd. You also want to look at the xlim/xmax ratio. The lower that is the greater the possibility of smacking a coil.
tvent
#3 Post by tvent » Tue Dec 11, 2018 9:56 pm
Thanks Bill. Again - you come through with flying colors! Great info.
Now I see - there is slightly more Vd with the 12, but that ratio is pretty much DOUBLE!
4 x WH10 melded
4 x WH8 melded
2 x Jack15 melded
2 x SLA Pro
Bought:
