4) Titan 48's and 4) DR 250's 7-14-2019
Post links to youtube videos of your cabs.
Forum rules
djtrumptight
#1 Post by djtrumptight »
2 Autotuba's MCM 55 2421
8 T48's 24"wide 3015 LF
2 SLA HT systems
1 Table Tuba Dayton DCS 255-4
2 T 39's 20" wide 3012 LF
1 T-18 13" wide MCM 55 2421
2 SLA Pro's
J_Dunavin
Re: 4) Titan 48's and 4) DR 250's 7-14-2019
#2 Post by J_Dunavin »
Nice!! How far back do you figure you walked?
#3 Post by Seth »
Nice :thumbsup:
Do you have them EQ'd at all?
djtrumptight
#4 Post by djtrumptight »
I dont really know how far it actually was but im thinking possibly 80 yards or more.Next week im going back to the same location but im gonna set up in a different area with both stacks facing the same way,i had them slightly splayed outward.Im gonna mark 4 spots at 25,50,75, and 100 yards.The reason i was showing the green dinosaur was to try to show the distance i was from the system.
Yes sir the tops are EQ'd but not alot,i like to bump the DR's 3khz area with a band pass filter and i tame that 10Khz hump a bit and boost the high end a bit where it falls off rapidly with a 19khz low pass.
Subs have a slight boost at 60hz with a bad pass filter,even tho they were stacked i kept the hi pass at 40hz instead of lowering it to 35hz.
2 SLA HT systems
2 SLA Pro's
#5 Post by Seth »
Nice. Thanks for sharing. I've watched all your other vids over the years too. Keep 'em coming :thumbsup:
djtrumptight
#6 Post by djtrumptight »
youre welcomed
2 SLA HT systems
2 SLA Pro's
